Welcome to Club SAITO !
Lonnie,
I do believe that was the box for the old Gemini 2 . Had a early and late 120 and a pair of 160 Gemini. Fine engines.
I have a box of NOS parts but have not seen it since the move.
Wow!
You and Dave are running some huge thrust engines! Eighty pounds? Awesome...,
Wow!
Gary you could send that $20 note downunder to see if it still works your fa170r3 gk looks better than my plain jane fa200r3.
Boys i think we have too many people named mike on this thread and it gets confusing, so i have a suggestion. They could each chose mike or mick or michael. Or maybe the other meaning for mike like pa system or megaphone or microphone because i think loudhailer okc has a certain ring to it did you know michael is an old hebrew name meaning " Who is like God? " someone here will snap that up for sure.....
Lonnie,
Wow!
Wow!
Gary, that box of nos os parts would be fun to rummage through. Let me know if it ever turns up.
Mike
Thats how my LT-40 is set up, a single dual output Life. It powers the RX, 4 servos and the FG-11 CDI. Can fly a couple hours before a recharge too. Looking at the weights, the OBG I am looking at it the most beneficial, and least expensive option. $75 vs $250 for CDI.
Question though on GP. When all three are connected together, with a single ground, is the voltage still 1.5V? It's the lack of current that is the issue here, right? I ordered 4 of those 5/8" twist lock GP connectors, I still need one for my Liberty Sport, so ordered enough for both planes. $7 each from RadicalRC.
I get multiple starts on multiple radials between charging.
Too simple for some. Simple enough fer me.
Actually Dave, not much different at all. Had both; If anything, the 120 is the easier of the two.
Pete,
I figure if I add a 50 Kilo ballast, I cold maybe double the thrust of my 325 radial.
I have an engine where the front bearing bore is opened up from spinning a bearing. I can pretty much just drop the front bearing in when the case is at room temp. Is there a permanent fix? If I try to dimple the bearing bore with a center punch, will the case crack? Anyone tried that to save a crankcase?
Lonnie, what about that clear/Blue glue that they use when they push in new piston liners on auto engine blocks. my friend Jack gave me some to use on screws inside my Chevy aluminum rocker covers, he said if I clean the cover and screws well the screws will never come out,
I guess that remains to be seen
Jim
Jim
Jim
The question is, how hard does it cure? Will it resist the compressive loads present even at operating temps? What happens when the bore of the aluminum case expands more than the steel bearing?
I could tell you never, ever dimple a bearing bore. But that is just me and the formal training I received.
In the application at hand, the small, front bearing does normally float axially in the bore. Bearing races rely on shafts and housings to maintain roundness.
Loctite bearing mount,(forgot the number has some success.)
At the shop, we usually resolved those issues by replacement, plating, sleeving or some other back alley hack shop methods
Loctite 620 or 680 (?)
I expoxied in a front bearing on an old fs70 a few days ago, it had the same problem, a spun front bearing. It hasn't bugded a thousandsth today over three tanks of fuel and runs just fine. I don't believe the front bearing moves axially at all, doesn't need to when there's a slip fit and clearance for movement at the rear bearing. I know, "we'll just agree to disagree", that is until you measure everything out as I have done and do the math.
Same here, been doing that often, quite often over fifty years, did it for a living.
That work had to last for years, production work, day in day out.
I know enough to disagree, and chuckle a bit too.
Correct. I marry 3000 maH c cells together in four packs. Then connect the four packs to a common connector. Then the motor gets a wiring harness that grounds with a single 12 gage wire to the case and individuals to the plugs Nice bright glo, easy starts. No obd weight or electronics. Inexpensive and easy to set up on multiple engines.
Crunch, your wing went out on Wednesday. There are a couple of machining magazines slipped under and taped to the side flap.
My Feedback: (102)
At one time I thought it would be cool to own many different brands of four stroke engines, So bought, Webra, Enya, OPS, Abitar, Conley, OS, Saito, RCV and Hi Max.
The Hi Max had an unusual feature, you could swap the intake and exhaust and criss cross the push rods in the tube on the back and run them reversed. I had a 91 and a 120. Pictured is a 120, the 91 was exactly the same physical size with a thick cylinder liner.
Hi Max 120 four stroke
