Welcome to Club SAITO !
My Feedback: (18)
RE: Welcome to Club SAITO !
You may want to heat up the case a bit with a heat gun and place the bearings in the freezer for a few hours. This will make the installation a bit easier by giving you a loose fit. After the temperature of both pieces normalizes, the bearings will be good and snug. Don't go crazy with the heat on the case.
Bob
Bob
My Feedback: (102)
OR, I use heat to remove some stubborn bearings on an old engine but never use heat to install the new ones. I use a brass drift and pnenolic hammer and gently tap around the outer race until it bottoms out. I push the front ones in using my vice and a socket facing the outer race 1/4' plywood behind the crankcase.
My Feedback: (13)
MN
Thanks for the replies.
It is about what I thought, but seeing as I haven't worked on a Saito yet, I figured I would ask if there were any quirks with Saito.
Greg
Greg
I have a FA82 on Seagull's AT-6 Texan, a FA91 on BH P47 and a FA100GK on Seagull Edge540. Awaiting my fourth, a FA115GK for my new project.
The pictures will follow.
I think I qualify to become a member.
Robert
Robert
I may be old school but I don't like applying heat to aluminum as I have been told this can distort the metal once it cools. Here's a trick that auto mechanics use to snug bearings. Get a ratchet socket that is the same size as the outside rim of the bearing and fits into the bearing casing of the block. Put some oils inside the bearing casing of the block to lubricate, put the bearing in the case so that it is properly aligned to push into the case, then place the socket on the outer rim of the bearing and gently hammer the socket until the bearing is pushed into place. Do this with the aluminum block resting on a piece of wood. It works all the time for me.
As promised, here are the pics of my planes with Saito power onboard:
P47 - http://picasaweb.google.hr/rvt464/P47Thunderbolt
Edge540 - http://picasaweb.google.hr/rvt464/Edge540
Pics with At6 will follow.
My Feedback: (102)
Do any of you Saito folks have a Saito 1.30 twin, I have this new/old one just about broken in and running WildCat 10% 2/4 cycle fuel with 18% synthetic lube and WildCat 10% Premium Extra I got the rpm you see on the tach. picture.
Prop===Graupner 15x8
Plugs (4) Fox miracle plugs
Exhaust (2) Saito .65/.80/.91 new cast mufflers and new all threaded pipes.
How does this compare, Thanks, Dave
My Feedback: (16)
I tried a 11 X 9 two blade APC on a 72 and had mid range richness problems as well as higher idle speed.
The three blade may be the way to go?
Opinions needed here.
Have a ST .45ABC mounted on a Lanier Radical profile plane.
Have the chance to swap it with a like new Saito .65
Will I see much of a difference power wise?
Running an APC 12.25 x 3.75 on the ST
My Feedback: (16)
The Saito 65 is heavy for its displacement. They run easy but don't have the power or light weight of the 62, 72, & 82 engines
Hello all
I've just encountered a new problem with my 62a and wonder if you could help.Over the last two or three days it's rapidly becoming inconsistent on the hs needle.Is there a way to search this forum specifically for that info? i'm suspecting a carb leak
Hi hobbsy and my apologies,i should have expanded on the symptoms and said that it's now almost impossible to prime these last three days.It stops wet with fuel and as it's inverted that takes a while to flick out,yet won't seem to draw any fuel when a cold finger prime and full throttle is used.Occasionaly i fluke a hot restart and she just sits there quite happily at tickover revs.Advance the throttle and a sweet pick up till around 5500 then it starts to go haywire surging a thousand rpm or so and at 7000 it's anybodys guess as far as to lean or rich.I've zeroed the needle and come out 4 turns then been up and down that hs needle in slow increments and nothing remains constant.I'm very wary of running it at full throttle if it's lean so always start rich.Five days ago it was turning a k series 12x6 masterscrew at 11000 which i richened back to 9800.The only other thing to be changed was i put an apc 13x6 on it three days ago and thats when it started to sound a bit iffy.Common sense would normally rule that out as unrelated but i feel like a treed coon over this one and wo'nt fly it till suss it out.
My Feedback: (16)
It comes with two Flex pipes I think. It also has a little clamp outfit for the pipes in a little cellophane package.
I bought two front pipes for the 100Ti to use on mine but I also had to buy two 90 degree adapters to make them work
http://www.horizonhobby.com/Products...odID=SAI90TS73
http://www.horizonhobby.com/Products...odID=SAI90TS74
You can also get extensions for the pipes
http://www.horizonhobby.com/Products...rodID=SAI50143
The engine is quiet with just the regular pipes. You don't need mufflers
Right angle adapter
http://www.horizonhobby.com/Products...ID=SAI100TI140
100T pipe with pressure tap
http://www.horizonhobby.com/Products...dID=SAI100TI74
Right angle adapter
Hi all,
I just bought a 72 GK and I'm wondering about the ideal fuel tank capacity. Does anyone have an idea ?
For flights lasting more than 15 minutes. Thanks.
Regards,
Paul
Regards,
Paul
My Feedback: (16)
I'm typically a 15 min man but not 3D. I run 10 0z with a 56 and 12 with the 91's
If you run 3D with a mostly partial throttle you could get away with 10 oz on a 72.
