Welcome to Club SAITO !
RE: Welcome to Club SAITO !
I have mounted my SAITO FA-80 on my GreatPlanes Cherokee 40 ARF !!!
[link=http://www.rcuniverse.com/forum/m_10419268/tm.htm]GreatPlanes Cherokee 40 ARF assembly thread....[/link]
My Feedback: (16)
ORIGINAL: Hobbsy
Jim, neither of my .80s nor the 1.50S have a letter on the lug. I don't know what that means if anything. That silver .80 I got in a trade in exchange for an Enya .90 fourstroke.My Saito collection is in pretty sad shape now at, a .30, .40a, FA .40, a .62, two .80s and a 1.50S.
My Feedback: (30)
Hobbsy,
Do you have any drawings or a sketch of your test stand you might be willing to share? I have been thinking of designing one but I like some of the features of yours just from the picture you posted.
My Feedback: (117)
I'm lusting over an FG-36. Any reason not to buy a clean 2 yr old one as opposed to the higher price of the new one? Have there been any big improvements on them in the last couple years? Thanks. And thanks for this loooong- interesting -informative thread. Brian
hey -glad to join??? I own an FA65it powers a Senior kadet Hi wing.
I fly an OSMAX 65 in a low wing Senior kadet.
I also have a YS 91 sitting on the counterdoes this diqualify me????
Roger in Kingman Az
Roger in Kingman Az
My Feedback: (102)
Thanks Rick, as Jim stated its a PSP, the board its mounted on is (3) 1/2" thick oak boards laminated together with 2 hour epoxy with the center board sticking out just far enough to mount the PSP. The PSP is then bolted to the center oak board using Vibra-Loc mounts from B&B Secialties/aka Bennett Built, the Vibra-Locs are on this page. Here's a shot of the Vibra-Loc setup.
http://bennettbuilt.com/page4.htm
Hi brian go to the gas engine forum there is a lot of info there.One club member has an fg36 very gentle to handle and run,his cuts out when it starts to go vertical i think he's lean best luck
Guys,
i am at work and i need to know the size of the x4 SHCScrews that hold the cylinder assembly
,tight, on the crankcase....
I must replace them because one of them failed while checking if these are tight or not...
It's for my SAITO FA-120S
My Feedback: (102)
If its the same as the 1.50 cylinder base bolts they are. 4mmx14 x.7 thread. The index on the slider is exactly lined up with 14mm, the camera did not pick up the index mark.
ORIGINAL: Hobbsy
And for the 1.80 FWIW.
Sincerely, Richard
I can't give you the size, but they are available as part number SAI120S14 from Horizon Hobby
http://www.horizonhobby.com/Products...odID=SAI120S14 for under $4 for the set.
Hope that this helps,
Bob
Bob
My Feedback: (102)
http://www3.towerhobbies.com/cgi-bin...&I=LXJ773&P=ML
http://www3.towerhobbies.com/cgi-bin...unts&search=Go
The second one is the whole page.
MI
Hi All,
This has probably been covered somewhere in the thread, but I can't seem to find it. So, forgive me if it has allready been addressed. Anyway, Is there a thread or site I can go to that will give me what I need to convert my 220 to gas?
Tom
Tom
IL
ORIGINAL: tacx
Hi All,
Tom
Hi All,
Tom
My Feedback: (149)
http://www.rcuniverse.com/forum/m_93...tm.htm#9474660
http://www.rcuniverse.com/forum/m_10...m.htm#10071228
http://www.rcuniverse.com/forum/m_72..._1/key_/tm.htm
http://www.rcuniverse.com/forum/m_10..._1/key_/tm.htm
Here are a few threads on conversions of 4-strokes, some even use the glow carb
Mike Brennan aka T-man49
Club Saito #723
Club Saito #723
Old Fart you aren't going to buy something on line are you??? What would Gerry (Harvey) say. Re those mounts for big engines, me I wouldn't use them I always use metal mounts and Saito makes some really good ones. Reasons for doing this are principally vibration and I believe a small reduction in resultantant HP. The vibration problem is emough for me my mentor (old Fart Jim H) saw a very expensive ESM machine bite the dust because and engine fell out of the model (approx 10 hours on engine and model no previous damage) and how do we know it was the engine because one fibre glass bearer was still attached to the engine. I still use F/G where weight is an issuebut the Saito and OS mounts are so light and strong that there is not a lot of difference.
BTB I am getting a book on Travelair Mystery ships from Amazon along with 3 other + 3 DVD's delivery cost AUD 27 the book is USD 29.95 6 weeks delivery sourced from a leading book seller in OZ AUD 93 plus 6 weeks delivery. Interesting huh
Nah just having a joke with kostus,he's a nice bloke
Been looking at the esm fw190 for an fa200 triple any excuse to buy that engine will do.The bulkheads on some kits are known to need a bit of home engineering and the books sound good will look at the site,cheers
