katana 120 with OS160FX set up help
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
Top Flite P-51D Mustang - 1/5 - RTF
Seller:  bblizzard
Details:   $1,500.00   |  11/16/2009   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> 3D Flying! >> katana 120 with OS160FX set up help
Page: [1]
Login
katana 120 with OS160FX set up help - 10/29/2003 3:21 AM
Kajundave2
Last Login: 2/3/2007
Status: offline
Ok guys, I picked up My katana 120 today, I will be making some mods, nylon wing bolts, longer hatch area, and move rear servos over the cg. its there anything I am missing ?
< Message edited by Kajundave2 -- 10/29/2003 3:23:02 AM >
Hide Signatures
       Post #: 1
RE: katana 120 with OS160FX set up help - 10/29/2003 8:07 AM
bn120
Last Login: 12/18/2008
Status: offline
fix the webing in the wings just double it up in the verticle direction.
Darin
Hide Signatures
(in reply to Kajundave2)
       Post #: 2
RE: katana 120 with OS160FX set up help - 10/29/2003 10:53 AM
Stiks
Last Login: 8/23/2006
Status: offline
If it's the GSP Katana check this thread out. Should give you an idea what to change
http://www.rcuniverse.com/forum/GSP_Katana_72%22%25%25%25DETAILED_BUILD_and_3D_FLIGHT_REPORT/m_1050950/tm.htm
Hide Signatures
       Post #: 3
RE: katana 120 with OS160FX set up help - 1/4/2004 11:52 PM
MAAC
Last Login: 6/15/2009
Status: offline
I have just taken delivery of a Katana S from Creek Hobbies. Are we talking hear and in particular the previous post about the same ARF plane?
Hide Signatures
(in reply to Stiks)
       Post #: 4
RE: katana 120 with OS160FX set up help - 1/7/2004 6:48 PM
bpannier
Last Login: 6/22/2009
Status: offline
MAAC..how does the kit look.Have considered Creek or Chief and do not know which one to get
Planned on using a G26 any comments. Thanks
_____________________________
73s Bud. AMA 739, WB7NDL
Hide Signatures
(in reply to MAAC)
       Post #: 5
RE: katana 120 with OS160FX set up help - 1/7/2004 8:35 PM
Rocketman_
Last Login: 6/23/2009
Status: offline
bpannier,
The Chief Katana 140 has built-up balsa and plywood wings and are covered with a heat-shrink film. The wings can be separated from the fuselage in two pieces for ease of transportation.
MAAC should be able to describe the Creek Katana for you. I have read in these forums that the Creek Katana has a foam wing.
Hide Signatures
(in reply to bpannier)
       Post #: 6
RE: katana 120 with OS160FX set up help - 1/9/2004 7:49 AM
mithrandir
Last Login: 6/19/2009
Status: offline
I have the GSP/CHIEF/CMP Katana... funnest plane I ever had!!!!
go here and check threads forward and back....
http://www.rcuniverse.com/forum/m_1050950/mpage_15/key_katana/tm.htm
I would also add, I made mistake of putting servos on CG, now I have 2 ounces
in the tail in addition to the battery pack! A total of over 5 ounces at tail!
I used an OS 160 with APC 18 x 6 prop. Bisson exhaust and perry pump.
I would estimate it is more power then a YS 140 L.
< Message edited by mithrandir -- 1/10/2004 5:20:04 AM >
Hide Signatures
(in reply to Rocketman_)
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.563RCU1
