Wayne Miller
Joined: 9/10/2003 Last Login: 6/23/2009 From: DrumboOntario, CANADA Status: offline
Hi, Latest update Oct. 7, 2008. Acronyms, Abbreviations, Short Forms Update Oct.7,2008 @ - short form for “at” in internet addresses, or “for” in sales Example 3 @ $5.00 – 3 for $5.00 & - This is an ampersand and means “and per say and” can be used to replace “and” in a sentence # - After a number means pounds Ex. 5# is five pounds. Before a number means number Ex. #5 means number 5. On a telephone it is referred to as the “pound sign”. / - Can be used to replace “or”. Example: “in/out” means “in or out” A – In electrical formulae this is short for Amp, a measurement of current. It takes 1000 milliamps to make one amp. The symbol for amp in electrical formulae is “I”. Example: I=E/R (that is: Amps = Volts divided by Resistance in Ohms). Also see other symbols E,R, and P. AAC – Aluminum, Aluminum and Chrome ABC – Aluminum, Brass and Chrome, or Aero Bird Challenger ABL - Advanced Bimetallic Liner (in our engines, bimetallic is typically brass and nickel) ABN – Aluminum, Brass and Nickel ABS – Anti-lock Braking System, or a type of plastic short form of Acrylonitrile Butadiene Styrene AC – Alternating Current, or Aerodynamic Center (of the wing) ACT – Test to do before flying A=antenna (up), C=controls (proper directions), T=throttle (quick runup and idle) AF 1 – Air Force One AFAICT – As Far As I Can Tell AFAIK – As Far As I Know AFO – Air Force One AFR – Adjustable Function Rate, used to adjust servo end points AFS - Active Flight Stabilization system Aft – Back of boat, plane etc. AGC – Automatic Gain Control Ailerons – Control surfaces at back of wing. Note: When standing at back of plane looking forward, and the right aileron moves up, and left goes down, plane banks to right AIM – AOL Instant Messaging short forms – texting or talking. Ex. “WTB” stands for “Wanted to Buy” AGL – Above Ground Level Airfoil – The curvature on a flying surface (wing, propeller etc.) that creates a lift or pull. AIUI – As I Understand It AKA – Also Known As AM – Amplitude Modulation, an alternative transmission method to FM, not used very much AMA – American Modeler’s Association, Academy of Model Aeronautics Analogue – In test equipment a meter with a dial (needle) read out. In RC a mechanical change caused by voltage fluctuation. Example: electrical motor control output to the motor. Angle of Attack – The difference between a surface going flat into the wind, and going into the wind at an angle. Anhedral – Wings droop down, the opposite of dihedral Angle of Incidence – See incidence AOA – Angle Of Attack AOT – Short for “as opposed to” APG – Aileron Positioning Guide ARC – Almost Ready to Cover ARF or ARTF – Almost Ready to Fly ARTF – Almost Ready To Fly a model that is mostly pre-assembled - see also Scratch Built, Kit Built, Plan Built, ARF and RTF AR – Aspect Ratio, relationship between the wing span and the wing chord ARO – After Run Oil ASAP – As Soon As Possible ASL – Above Sea Level Attachment – A file attached to an email ATV – Adjustable Travel Volume, limits servo travel distance either side of center, or All Terrain Vehicle. See EPA also. Auto Shift – New Hitec receivers with Auto Shift can be used with any brand of modern FM transmitter. AUW – All Up Weight (total weight ready to fly. some include fuel, some don't... should include fuel though.) AWARF - All Wood Almost Ready-to-Fly AWOL – Absent Without Leave b4 – Short for “before” BA – British Association Thread designation BA – British Airlines Bash or bashing – To change or modify a model. Also, may mean to speak negatively about a thing or person. BB – Ball Bearing BBS – Bulletin Board System BC or B/C – In emails, short for “because” bcnu – In emails short for “Be Seein’ You” BCP – Blade Collective Pitch, a popular micro helicopter model with collective pitch, see also FP BEC – Battery Eliminator Circuit Bevel – To shape material to make an angle. Example: The front of ailerons where the hinge goes in are beveled (angled) to allow the aileron to pivot up and down at the hinge point without hitting the wing. BF – Short for “before” or Bayerische Flugzeugwerke Bavarian Aircraft Works - Willy Messerschmitt's company and makers of the Messerschmit ME109 bfn – Short for “bye for now” BIT – Built In Testing BL – Brushless, refers to electric motors Blog – Stands for weblog. This is a personal newsletter, or point of view, updated regularly and available to any web surfer BMEP – Break Mean Effective Pressure BMFA – British Model Flying Association BOB – Best On Board (passenger) or Bomb On Board BOD – Beginning of Descent BRB – Be Right Back Browser – Software used to access the internet BS – Bull Stuff (or substitute “stuff” with your locally used word) BTE – Bruce Tharpe Engineering btt – Back To the Top, used to direct reader to the top of a forum or tell them to start over BTW – By the Way BUHOR – Big Ugly Hell On Rails BUMP – It has been suggested this means “Bring Up My Post”. Any sort of text response to get the message to the top of a forum or active again BUSA – Balsa USA BVM - Bob Violet Models BYOB – Bring Your Own (pick one) Bottle/Broad/Booze/Bedroll/Blanket/etc. C(number) - Capacity times the number. Example C10 is ten times the capacity of a battery in ma. C10 for a 3000 ma (3.0 amp) battery pack would be 30,000 ma, or 30.0 amps. C/(number) -Capacity divided by number. Usually used to describe battery charge rates. Example C/10 is the battery capacity in ma divided by 10. In the case of a 3000 ma (3.0 amp) pack this would be 300 ma C/W – Short for “complete with” CA – Cyanoacrylate Adhesive (a quick setting glue) CAD – Computer Aided Design CAM- Computer Aided Manufacturing Carb – Short for carburetor cc – Cubic Centimeters CC – Castle Creations CCW – Counter Clock Wise CCPM – Cyclic Collective Pitch Mixing, a mixing of three servos to control helicopter CDMA - Code Division Multiple Access, used with cell phones CF - Carbon Fiber CIPP – Cured In Place Pipe, a composite liner to re-enforce old pipes, such as sewage CG – Center of Gravity or Carl Goldberg (Models) CGM - Carl Goldberg Models Charge or Charging – To replenish or fill. In modeling, to put energy into batteries. CIM – Computer Integrated Manufacturing CL – Control Line Clevis – A clip on connector between a control (push) rod and servo, control horn or throttle. cm – Short for centimeter. In emails its short for “call me” CMP – Chinese Model Production CNC - Computer Numerically Controlled, a computer-controlled process for manufacturing parts Cockpit – The area a pilot sits to control an aircraft. COL – Cry Out Loud Control Surface – A surface that controls wind deflection for controlling movement, such as, aileron, elevator, rudder flaps etc. Cos or cus – Short form for “because” CP – Center of Pressure, or Coroplast (it’s like a plastic cardboard they make signs out of) CRAFT - Can't Remember A Frigging Thing (or substitute “frigging” with your own locally used words) CR or C/R – Compression Ratio Crank – Short for the “crank shaft” of an engine. CRATT - Coded Radio Airborne TeleType CRS – Can’t Remember Stuff (or substitute “stuff” with your locally used word) CRT Cathode Ray Tube Crow – When flaps go down and ailerons go up, gliders usually use this as an air brake CU – See You - as in See You later Current – The moving of electrons through an electrical device. Designated as I one unit is A (ampere) CW – Clock Wise cw2cu – Short for “can’t wait to see you” CYA – Cover Your Aft (substitute “Aft” with your locally used) DAW - Dave's Aircraft Works (bought out by http://skykingrcproducts.com/ ) DC – In electricity - Direct Current, or when referring to Radio Control radio receivers – Dual Conversion Dead Stick – Motor stopped and flying (gliding) without power DGA – Damn Good Airplane (or Aircraft) DH – Dear hubby DHC - DeHaviland Canada Dialed in – The model is perfectly tuned Diameter – In regards to propellers, the distance from tip to tip of a propeller Digital – In RC, a change related to pulse width, example servo movement, the longer the pulse the more movement. In everyday life a display that has numbers or can be read. Dihedral – Wings that angle upwards from the body of the plane (wing root) to wing tip. Looking at the wing from the front of the plane, it would look like a flattened “V” Dive Brake – Surfaces on a wing to create a drag to slow airspeed when deployed. DIY – Do It Yourself Dope – A type of paint used while covering aircraft, there are two types Nitrate (not fuel proof) and Butyrate (fuel proof). Nitrate dope can paint over Butyrate dope, but Butyrate can not go over Nitrate. DR or D/R – Dual Rate, usually a switch on the transmitter to allow longer/shorter servo travel DRM – Digital Rights Management, a software protection scheme DRRC – Driving Radio Control Canada magazine DSC – Direct Servo Control, control of servos by a cord from transmitter without transmitting a signal DST – Daylight Saving Time DSQ.-. Disqualified or disqualification DT – Digital Trim DW – Dear Wife Dynamic Soaring - Using the up and downdrafts of a slope to build speed with a glider. E – Electrical symbol for voltage. Example formula: E=IR (that is: Volts = Amps divided by Resistance in Ohms). Also see other symbols I,R,A, and P. EBT - Earnings Before Taxes eCCPM – Mechanically Cyclic Collective Pitch Mixing, see also “mCCPM” ECM - Electronic Counter Measures EDF – Electric Ducted Fan Eff - Effiency EFI – Electronic Fuel Injection EGT – Exhaust Gas Temperature Elevator – Horizontal control surface at back of plane. Note: When back of elevator goes up, plane goes up. Elevons – When aileron and elevator functions are combined. Example - delta wing aircraft EMAS - Engineered Materials Arresting System, barriers to slow down vehicles EMC - Electromagnetic Compliant Energy – Designated as E and is the result of Power times Time usually expressed in Joules(j) or kilowatt Hours(kWh) EOC – End of Climb FOD – Foreign Object Debris, Foreign Object Damage EPA – End Point Adjustment. See ATV also. EPP - Enhanced Poly Propylene E Props – Electric Propellers, used on electric planes blades are not as wide, and hubs are larger than SF Props. Usually used on outdoor electric planes. ET – Elapsed Time ETA – Estimated Time of Arrival E-TOC - Electric Tournament of Champions ESC – Electric Speed Control Expo – Short for expotential, in Radio Control it is the ratio of the transmitter stick movement to the servo movement. Typically more stick movement, for small servo movement thus finer control f - Frequency F2F – Face To Face FADEC – Full Authority Digital Engine Control FAI - Fédération Aéronautique Internationale FAQ – Frequently Asked Questions FCC – Federal Communication Commission FCOL – For Crying Out Loud FFF – Fan Fold Foam FFL – French Foreign Legion FG – Fiberglass FIDO...Forget It, Drive On (or substitute “forget” with your locally used word Fin – The vertical stabilizer, that is, the tall, thin, upright nonmoving part of an aircraft’s the tail assembly. Flame – To insult or vent disapproval Flaperons – Ailerons that can be used both as ailerons and/or flaps Flight Simulator – In radio control, a program used on a personal computer to simulate flying a model aircraft with joysticks or a radio control transmitter. Flute – The veins in coroplast (the plastic cardboard) that is used in making SPAD model aircraft FM – Frequency Modulation, most common method of transmission used today for Radio Control FMS - Flight Management System FNV – Front Needle Valve, usually high speed adjustment when located on carburettor FO or F/O – First Officer FOAD - Fly Off and Die. (Substitute “Fly” with locally used words) FOD - Foreign Object Damage or Foreign Object Debris FOS – Full Of Stuff (Substitute “Stuff” with locally used words) Forward – to the front of boat, plane etc. FP - Fixed Pitch FRED - Friggen Ridiculous Electronic Device (Substitute “Friggen” with locally used words), also means Flashing Rear End Device on trains. Freq - Frequency Frequency – The amount of repetitions in a specific amount of time. Designated as f, one unit in electricity is Hz (hertz) FRRC – Flying radio Control Canada magazine FS – For Sale or Fail Safe, usually a preset position for servos to move to when radio transmission is lost FSK - Freqency shift keying FSW – Forward Swept Wing FTW – For The Win FUBAR - Fouled Up Beyond All Recognition (Substitute Fouled with locally used words) Fuse – Fuselage Fuselage – The main body of an aircraft FWIW – For What It’s Worth FYI – For Your Information g - grams G - Gravity force factor. Example 1G = normal weight, 2G = two times weight g2g – Short for “got to go” Gas – short for “gasoline”, example a fuel for automobiles GB – Gear Box GG – Gotta Go or Gorilla Glue (a polyurethane glue, another common brand name is Elmer’s Pro Bond) GJ – Good Job Glow Plug – A screw in plug, usually at the top of a glow engine, with a platinum coil that requires heat to ignite alcohol to start the combustion process, once started, the heat from subsequent combustion keeps the coil hot and the engine working. Glow Engine – An engine that relies a glow element to operate. GMAB – Give Me A Break GMS – Gemtec Machinery Systems (makers of GMS engines) Goodwin’s Law - Godwin's law. Gopher – short for “go for”, or a menu driven system to get information GP - Great Planes Mfg. Co. GPM – Gallons Per Minute GPS – Global Positioning System, an electronic system to find a location or position gr8 – Short for GREAT GSP – Giant Scale Planes GST – Government Sales Tax GTG – Got to Go gyab – Give Yourself A Break H9 - Hangar 9 Mfg Co HD – High Density HDG – Heading as in runway approach heading Hertz – A unit of frequency defined as one cycle per second HF- high frequency or Human Factor HIS - Horizontal Situation Indicator HOC – Hot Off the Charger HOR – Hell On Rails Hover – To suspended an object in one place using an internal or external power source. Hotliner - A high speed electric assisted glider HS – High Speed or Hobby Shop HSN – High Speed Needle, high speed adjustment on a carburetor HTML – Hyper Text Mark-up Language HUCFU- how you can frig up, substitute your locally used word for frig (see also human factor) HW – Hobby Warehouse Hydro – short for electricity, or in SCUBA compressed air tanks (used for starting jets )short for Hydrostatic testing and must be done every 5 years Hz – see hertz I – Current in amps (Example formula: I=E/R) IPD – Intelligent Pulse Decoding - Decodes faster than PCM. Allows setting failsafe point for your servos and only valid signals. IFF - Identification Friend or Foe Iemax – Current IFR – Instrument Flight Rules IIRC- If I Recall Correctly ILS – Instrument Landing System IMAC - International Miniature Aerobatic Club IMHO – In My Humble Opinion or In My Honest Opinion IMNSHO - In My Not So Humble Opinion IMO – In My Opinion Inl – No load current In The Bones – A plane that has been build and framework completed, but is not covered yet Incidence – The difference in between a surface (wing) being parallel to the center line of the aircraft and a wing offset from the center line. If the front of the wing is up, its positive, if down its negative. IPR – Intelligent Power Reduce IRC - internet relay chat IRCHA - International Radio Controlled Helicopter Association IRL – In Real Life ISP – Internet Service Provider ISTM – It Seems To Me JMHO – Just My Humble Opinion or Just My Honest Opinion J – Joule, a unit of work/energy J – Torque (oz-in/A) JIT – Just In Time, usually to receive parts just in time for manufacturing, thus reducing inventory JMO – Just My Opinion Joule – The work done when the force of 1 newton goes 1 meter JR – Japan Radio JSF – Joint Strike Fighter (F35) Kb – Voltage constant (Volt/1000rpm) KISS – Keep It Simple Stupid Knife Edge – To fly a model “on its side”, the wings are vertical to the ground instead of horizontal Kg – Kilograms Kt – Torque constant (oz-In/A) KOW – Knock On Wood KPH – Kilometers per Hour Kv – Kilovolt or 1,000 volts. With electric aircraft motor specifications Kv means 1,000 RPM (revolutions per minute) per volt kWh or kW-hr – Kilowatt Hours a measurement of how many thousands of watts used per hour L8R – Later as in CU L8R LAR – Looks About Right Lawn Dart – A model aircraft with its nose buried in the ground, or a model airplane fuselage that lost its wings mid flight. LNIB – Like New In Box LSI – Large Scale Integration Kit Built – To build a model from a kit see also Scratch Built, Plan Built, ARF, ARTF and RTF Lbs. – Pounds LCA – Landing Craft, Assault LCD – Liquid Crystal Display LCI – Landing Craft, Infantry LE – Leading Edge LED – Light Emitting Diode LF – Looking For LG – Landing Gear LH – Left hand side (in reference to ships and airplanes – left hand side of pilot facing forward) LHS – Local Hobby Shop LiPo, or Li-Po, or Li-Poly – Lithium Polymer battery Li-ion – Lithium Ion Battery LMFAO – Laughing My “Freaking” “Aft” Off, (substitute freaking and aft for locally used words” LMK – Let Me Know LOA – Length Over All, in model aircraft usually measured from tip of nose cone to end of rudder LOL – Lots Of Laughs, or Laugh Out Loud, or Lots Of Luck Low Wing – An aircraft with the wing on the lower part of the fuselage. Loop – An inside loop is a maneuver where an aircraft goes into a vertical circle using up elevator (an outside loop uses down elevator). LS – Low speed LSN – Low Speed Needle, low speed needle valve adjustment on a carburetor, usually affects low and intermediate speed (transition) adjustment Ltr – Liter Lurker – A person who visits, and reads, bulletin boards and forums but never posts anything LVC – Low Voltage Cutoff circuit LWL – Length at Water Line ma – Milliamp, one thousands of an amp MAAC – Model Aeronautics Association of Canada MAC - Mean Aerodynamic Chord (I think this is the center of gravity/balance point?) mah – Milliamps per hour, milliamps times hours, one thousands of an amp. Milliamps is a current rating used to determine the number of milliamps used, or stored, for one hour MAP – Manufacturer Adjusted Price MASH – Mobile Army Surgical Hospital Max – Maximum mbrsd – Short for “embarrassed” mCCPM – Mechanically Cyclic Collective Pitch Mixing, see also “eCCPM” MCM – Mousse Can Muffler MCP- Mousse Can Pipes (mufflers made from hair styling mousse cans) MD – Stamped on side of K&B engine – means Model Direct, a direct sales promotion engine sold in late 90’s ME – Short for Messerschmit the ME-109 was designed by Willy Messerschmitt MECOA - The Model Engine Company of America MG – Metal Gear MGBWY – May G od Be With You MK - Monokote or Mark (as in Mark II) MIA – Missing In Action Min – Minimum mIRC - is a client program to access IRC mm – millimeter MOOTWA-An acronym for Military Operations Other Than War Mode 1 – Transmitter with Rudder and Elevator on left stick , Aileron and Throttle on right stick Mode 2 - Transmitter with Rudder and Throttle on left stick, Aileron and Elevator on right stick Mode 3 – Transmitter with Aileron and Elevator on left, Rudder and Throttle on right stick Mode 4 – Transmitter with Aileron and Throttle on left stick, Rudder and Elevator on right stick Mode Single stick – see single stick Mosaic – an older web browser MPH – Miles per Hour MSDS - Material Safety Data Sheet MT – Monster Truck MTBF – Mean Time Between Failures, a rating given by manufactures for failure rates MTTR – Mean Time To Repair, the time for the average repair of an item mv – millivolt MWC - Model Warship Combat NA or N/A – Not Available NAR - the National Association of Rocketry NCN – No Covering Needed NE1 = Any One - as in does NE1 know? NEAT – Northeast Electric Aircraft Technology fair Newbie – A new person or beginner Newton – The force created by an acceleration of 1 meter per sec. per sec. by 1 kilogram Netscape – A web browser NFG – No Frigging Good (or substitute “frigging” and/or “gosh” with your own locally used words) NIB – New In Box NiCd – Used to describe a type of battery - Nickel Cadium NiMh – Used to describe a type of battery - Nickel Metal Hydride NIP – New In Package NNIB – Nearly New In Box NOS = New Old Stock NP – Neutral Point NR – Never Run NV – Needle Valve NVM – Never Mind OAN - On another note OHV – Over Head Valve OMF G – Oh My Frigging Gosh (or substitute “frigging” and/or “gosh” with your own locally used words) OMG -Oh my Gosh (or substitute “gosh” with your locally used word) OMP - Ohio Model Products (or Planes?) One point landing - Landings (crash) usually performed by lawn darts. Ornithopter – An aircraft that flies by flapping its wings. OTH or OTOH- On the other hand OWB – One Way Bearing Oz – Ounces P – In electrical formulae it is short for Power in watts. Example formula: P=EI (Power = Voltage multiplied by amps. See other symbols E,I,A and R. P/W – Power to Weight ratio PBF – Pizza Box Flyer PBY – As in “PBY Catalina” aircraft, P means Patrol, B means Bomber and Y is the designation for the Consolidated Aircraft Company PCM - Pulse Code Modulation PDQ – Pretty Darn Quick (or substitute “darn” with your locally used word) Peak Detect – Usually refers to charging batteries, a method to check peak voltage when charging batteries Period – Usually a time period and is designated as T, one unit is s (seconds) Pi- Power input (Watts) PIA or PITA– Pain In The Arm (or substitute “Arm” with your locally used word) PITN – Pain In The Neck Piston – A mechanical device that moves in a cylinder to deliver/receive pressure, transfer combustible energy, or move liquid or air. Pitch – In reference to propellers, the angle of propeller blade, the higher the number the greater the angle Plan Built – A model built from printed plans, parts are cut, assembled, and exterior is finished by modeler - see also Scratch Built, Kit Built, Plan Built, ARF, ATRF and RTF PMDG – Precision Manuals Development Group PMP - point of maximum pucker - that is the reaction when avoiding a crash or a close call Poly Urethane Glue – An expandable glue that requires water to set, Examples: Gorilla Glue or Elmer’s Pro Bond Po – Mechanical power output (Watts) PoP – Point of Presence, the access point of a system to the net Port – Left hand side (when pilot faces forward), or an opening in a boat or plane, or boat docking area POS – Piece of Stuff (substitute “Stuff” with your locally used word) POST – Power On Start-up Test Power – Is the work done by electricity and is the result is calculated by the Voltage (V) times the Current(I). It is measured in Watts(P). (Example formula: P=EI) Ppl or ppls – Short for “people” or people’s PPM – Pulse Position Modulation PQHOR – Profile Quick Hell On Rails (a SPAD aircraft) BroBros – The Profile RC Brotherhood – the web site is: **** PROF – Pending Receipt Of Funds Prop – Propeller Propeller – Usually located at the front of an aircraft or at the back of a boat in the water, it spins to move air or water to propel the aircraft or boat Prop Wash – The wind, or water movement created by a propeller when it is turning PSI – Per Square Inch PST – Provincial Sales Tax PUA – Poly Urethane Adhesive – examples: Gorilla Glue or Elmer’s Pro Bond Pusher – In model aircraft, a craft that has a propeller located someplace behind the wing, or at the back of the aircraft to “push” air instead of a propeller at the front “pulling” air to create forward motion. R – In electrical formulae, resistance in ohms. Example formula: R=E/I (Resistance in Ohms = Voltage divided by Amps). See other symbols A,E,I, and P. RAAWS - Radio Altimeter And Warning System RADALT - RADio ALTimeter Radial Engine – An engine with three or more cylinders, usually evenly spaced, going around the engine RAF – Royal Air Force RATO- Rocket Assisted Take Off RC or R/C – Radio Control or Remote Control RCA – Radio Corporation of America, or Royal Canadian Army RCM – Radio Control Modeler (a magazine) RCU – RC Universe a web site for radio control enthusiasts Resistance – Designated as R and one unit is (ohm). Is a value of how much an electrical device limits the electric current: One volt applied to a resistance of one ohm has a current of one ampere. Also see symbols R,A,I,E and P. RFI – Radio Frequency Interference RH – Right hand side (in reference to airplanes – right hand side of pilot when facing forward in cockpit) RIP – Rest In Peace RLV – Reusable Launch Vehicle Rm – Terminal resistanceRNV – Rear Needle Valve, high speed needle valve mounted at rear of engine RO - radio operator ROFL - Rolling On the Floor Laughing ROFLMAO - Rolling On Floor Laughing My “Aft” Off (or substitute “aft” with your locally used word) ROG – Rise Off Ground, or Rolling On Ground Roll – An aircraft maneuver where the aircraft rotates around the fuselage, usually using ailerons, while moving forward Rotate – Another term for turning or pivot. Ex. A propeller rotates, or an aircraft body rotates at point of take off. Also see V2. ROW – Rise Off Water RPM – Rotations Per Minute or Revolutions Per Minute RPM/V – Rotations Per Minute per Volt or Revolutions Per Minute per Volt RTR – Ready To Run (or Roll) RTV – It stands for Room Temperature Vulcanization and is reference to “RTV Silicon Adhesive Sealant”, and is similar to other silicon rubber sealant products. RU – In emails short for “are you” Rx – Receiver RTF – Ready To Fly a model that comes fully assembled with radio - see also Scratch Built, Kit Built, Plan Built, ARF, ATRF and RTF RTFM – Read the “Friendly” Manual, (substitute “friendly” for your locally used word) Rudder – Back vertical control surface at back of plane. Note: When back of rudder goes right, plane will be directed right, works with nose wheel on tricycle gear or tail wheel on tail dragging airplane. RV – Recreational Vehicle SAM – The Society of Antique Modelers -http://www.antiquemodeler.org/index2.html SASE – Self Addressed Stamped Envelope SC – Single Conversion when referring to radio receiver, or Supercharger SC – Step Climb Scramjet – Supersonic Combustion Ramjet Scratch Built – A model designed, cut out, built and covered by a person - see also Kit Built, Plan Built, ARF, ATRF and RTF Sec – Seconds Single Stick – Transmitter with one stick, Aileron and Elevator on X and Y axis, Rudder Knob on end of stick and Throttle (a trim lever type control on the case) Semi-Symmetrical wing – A wing with bottom airfoil not the same as top airfoil, will be less on bottom SF Props – Slow Fly Propeller, usually used on indoor electric planes and can be distinguished by small hubs and wide blade SFG - Side Force Generators, vertical wing fins to give more surface area and stability in knife edge flight SMT – Surface Mount Technology Snail Mail – Mail sent through the postal service SNAFU - Situation Normal All Fudged Up (substitute “fudged” with your locally used word). S-o-C – State of Charge, used in reference to batteries to identify how much charge capacity they have. SPAD – Simple Plastic Airplane Design Spam– Unsolicited email, usually advertisements SPFBD – Simplified Plastic Flight Box Design Spamming – The sending of Spam Spec – Specification Spoofing – Using a false email address as an email return address S-PPM – A JR receiver fail safe mode that will cause the servos to “hold” then go to a programmed preset position after a predetermined period of time of lost or scrambled signal Sq in – Square Inches SS – Stainless Steel SSDD – Same Stuff Different Day (substitute “stuff” with your locally used word) SSS – Sudden Silence Sucks SST – Super Sonic Transport Stab – Horizontal Stabilizer, the flat, wide, nonmoving part on an aircraft’s tail section. Stall – In aircraft, the point where there is not enough lift to keep it flying Starboard – Right hand side (when pilot faces forward) STD – Standard Stick Time – Time spent flying STOL – Short Take Off and Landing Strk – Stroke as in 2-strk or 4-strk sup – Short for “what’s up?” Super Charger – A power assisting device that compresses air into an engine SUS – Sudden Unintentional Starting Sweat – To join two pieces of metal together that have been tinned, that is, coat two pieces of metal with solder, then hold together and heat until the solder melts and joins the pieces. Also see “tin”. Swarf – Small particles of metal left in an item after manufacturing SWAG – Stupid (Scientific) Wise Aft Guess (substitute “aft” with your locally used word) Symmetrical wing – A wing with same airfoil on top as bottom T&G – Touch and go, when an airplane comes for a landing, touches, and immediately takes off T – Teeth (usually the number on a gear) TANTAAFL - There Ain't No Such Thing As A Free Lunch TARFUN - Things Are Really Fouled Up Now (substitute “fouled” with your locally used word) TAXI – A controlled steering and moving of aircraft under power while on the ground TBA – To Be Announced TBC – To Be Calculated TBD – To Be Determined TD – Tail Dragger TE – Trailing Edge TF – Top Flite Thermal Detect – The detection of heat of an object TIA – Thanks In Advance Tin, Tinned, or Tinning – To coat with solder, usually used to “sweat” two pieces of metal together. Also see “sweat”. TLAR – That Looks About Right TMTOMH – Too Much Time On My Hands TNX – thanks or thank you to or t/o – Take Off TOC – Tournament of Champions Toe-in – This is a term to describing when the front of a pair of wheels on a vehicle are pointing toward each other (inward). This is needed on tail dragger aircraft to avoid poor ground handling. Toe-out – This is a term used to describing when the front of a pair of wheels on a vehicle are pointing away from each other (outward). TOF – Time of flight from leaving ground to touch down. Calculation for electric TOF in minutes is: battery capacity in amps, divided by average current draw in amps, times 60 TPTB – The Powers That Be TR or T/R – Thrust Reverser Trammeling – Aligning fuselage, wings, horizontal stabilizer, vertical stabilizer and landing gear Troll Post – A bulletin board posting designed to create controversy and may or may not be related to fact TTYL – Talk To You Later ttt – To The Top, to put an item to the top of a forum, or to start over TU - Tango Uniform, or “Tips Up”, meaning a complete failure (or substitute “tips” with your locally used word) Turbo – Turbo Charger, a device to compress air into an engine that is not power assisted (see super charger) TVM – Thanks Very Much Tx – Transmitter TY – Thank You U – European designation for Voltage, or in emails Short for “you” UAT – Ultimate Air Trap – A hopper tank containing a mesh filter designed to eliminate air bubbles in turbine fuel lines. Trade marked by BVM UAV – Unmanned Aerial Vehicle UC – Ultracote, or U-Control control line models - the name comes from the shape of the control handle UFO – Unidentified Flying Object UNEF – United Nations Emergency Force or regarding bolt threads Unified Extra Fine UNODIR - UNless Otherwise DIRected ur – In emails, short form for “you are” URL Uniform (or Universal) Resource Locator USPS – United States Postal Service USSR – Unites Soviet Socialist Republic uuencode – An older method of converting (encoding/decoding) binary files to text based characters UWYH – Use What You Have V – Volt, the force required to put a current of 1 amp through a 1 ohm resistance V1 – Means the maximum speed (point) in the takeoff at which time the pilot must make the decision to take off or abort the takeoff V2 - The takeoff speed when the airplane can be safely rotated for takeoff VAT – Value Added Tax (European) VE – Volumetric efficiency VFR – Visual Flight Rules VGC – Very Good Condition VIP – Very Important Person, In SCUBA compressed air tanks (for starting Jets) it means Visual Inspection Process and must be done once a year VMO – Maximum aircraft operating speed vs – versus Voltage – The electrical force to drive current through an electrical conductor. Designated as V (North America), U (in Europe) and one measurement unit is V (volt) VPP – Variable Pitch Propeller VR – Rotation Speed, the speed at which the aircraft rotates from the runway and start to climb Vref – The minimum landing approach speed VTOL – Vertical Take Off and Landing VTR – Variable Trace Rate, allows different servo speeds for each half of transmitter stick, similar to expo VVVF – Variable Voltage Variable Frequency W/ – With W/O – Without W3 – Short for World Wide Web, see “web” WAAS – Wide Area Augmentation System a GPS (see GPS) system to accurately find location Washout – The trailing edge of a wing gradually goes upward at the tips, this creates less lift at the wingtips and causes the tips to keep flying when the center section stalls, creating more stable slow speed flying. Watt – The power used when 1 amp (direct current) flows through 1 ohm. A unit of measurement for power – see “P” Web - A network of computers linked together to share information through a common communication link, may also be called WWW (World Wide Web) or short formed as W3 Wing Loading – The weight each square foot (or square inch) of wing has to support (carry). Formula for wing loading in ounces per square foot is: weight of plane (in oz.) divided by wing area (in sq. inches) times 144. For wing loading per square inch, do not multiply by the 144. WIG – Wing In Ground Effect Winsock – A cone shaped piece of material open at each end to tell the direction of the wind. Also short for “Windows Socket”, a file usually used to connect Windows through a software link to the net WJM – World Jet Master (Team) WM – World Models WMP – World Model Products WOF – Wood Over Foam WOT – Wide Open Throttle WTB or W2B – Where To Buy or Want To Buy wtd – Short for “wanted” W T F – What The Fudge or Who The Fudge (or substitute “fudge” with your locally used word) WTG – Way To Go WW1 – World War One WW2 or WW II– World War Two WYSIWYG – What You See Is What You Get. - usually pertains to sales of an item as "AS IS" www – World Wide Web, see “web” X–wind – Cross wind XTAL, xTAL, or xtal – Short for “Crystal”, this typically is a plug in component that determines the channel (frequency) for your transmitter and/or reciever Y–Harness – A harness that plugs into receiver and has servo two plugs, used for two servo ailerons YCD – You Can Do YGMV – You Got My Vote YMMV – Your mileage may vary YHM – You Have Mail YW – Your Welcome Z-PPM – A JR receiver fail safe mode that will cause selected servos to “hold” their position, and other selected servos to go to a programmed preset position, after a predetermined period of time with a lost or scrambled signal. +++++++++++++++++++++++++++++++++++++++++++++++++++++++ To cut and paste the list into your favorite word processor for printing, first highlite the list with your mouse, then push "CTRL-C" (copy), open your word processor and push "CTRL-V" (paste). The above is to the best of my knowledge, and should be considered a starting point. Please let me know any changes you would like to see - any, and all, suggestions are welcome. Wayne Miller
Hide Signatures
