RE: FSA Clubhouse
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> The Clubhouse >> RE: FSA Clubhouse
Page: <<   < prev  1 [2] 3 4 5 6 7 8 9 10   next >   >>
Login
RE: FSA Clubhouse - 10/20/2005 7:31 PM
kkling77
Score: 100
Last Login: 6/22/2009
Status: offline
quote:
ORIGINAL: Montague
Fwiw, I have been working on a clarified version of the heli flight rules. This is a draft version. There may be changes.
- Helicopters must take off and land from the center of the runway. Putting the helicopter on the edge of the runway (just past the white line) does not provide enough seperation space between the helicopter and the pits. (This is simular to the expectation that fixed wing aircraft will take off and land roughly in the middle of the runway and should not be trying to take off and land right on the runway edge). This means that all helicopters must be carried out to the center of the runway prior to take off.
- All flying of helicopters must take place beyond the far edge of the runway, over the tall grass. This speicifically includes all extended hovering.
- After taking off from the runway, all helicopters must move directly outwards over the tall grass or to the left and then out over the tall grass. (This avoids having a helicopter depart directly across in front of other pilots in the pilot boxes).
- When landing, helicopters will always approach from the left, and land to the left of the flight boxes. (This avoids crossing directly in front of the other pilot boxes at a low altitude and close in).
- Acrobatic takeoffs (high rate of ascent, piretting, etc) shall only be done at the far left end of the runway, and only after the helicopter has taken off normally, flown, and landed at the extreme end of the runway.
- Autorotations and other acrobatic landings shall be performed as a normal landing, ie, only from the left, and not extending to the right of the helicopter pilot box.
- The helipad is for hovering only. No transitional flight or forward flight is allowed in the helipad area. The space is too small for such activity.
- When flying at the helipad, the pilot will stand with their back towards the parking lot. At no time shall the helicopter be closer to the parking lot than the pilot.
Why are people getting so bent out of shape about helicopters in general when it is in fact just one individual who people are really having a problem with? A helicopter CAN be operated just as safely as an airplane. The proposed "rules" above seem to be overkill, and in some cases absolutely ridiculous.
For instance, "All flying of helicopters must take place beyond the far edge of the runway, over the tall grass. This speicifically includes all extended hovering." I agree with this rule, however isn't this also a rule for fixed wing aircraft also? Just about every time I am at the field I see this rule broken at least a handful of times. In fact, Mr. president, I have actually seen you fly down the middle of the runway with your combat plane hit the propeller on the ground and deadstick on the runway. Afterwards you were so excited, exclaiming to others "did you see that?" If this rule is going to be enforced, than it should be enforced for EVERYBODY!! If not, than let's make it a free for all and see who can fly the fastest, lowest to the ground, and closest to the flight boxes.
The next rule, "After taking off from the runway, all helicopters must move directly outwards over the tall grass or to the left and then out over the tall grass. (This avoids having a helicopter depart directly across in front of other pilots in the pilot boxes)." Airplanes take off left and right don't they? What is the difference with a helicopter taking off left or right if it is in the center of the field? This means that we should make all fixed wing aircraft make a 90 degree turnout over the high grass as soon as they lift off so as not to cross in front of other pilots.
The next rule, "When landing, helicopters will always approach from the left, and land to the left of the flight boxes. (This avoids crossing directly in front of the other pilot boxes at a low altitude and close in)." So that means if there is a 15 mph wind from the left you still expect me to land from the left? How ridiculous does this sound. Personally I tend to land anything I fly into the wind. Again, why is it an issue to cross in front of the pilot boxes at the centerline of the field. You say "at a low altitude and close in." That isn't any closer than where fixed wing aircraft are landing.
Next rule, "Acrobatic takeoffs (high rate of ascent, piretting, etc) shall only be done at the far left end of the runway, and only after the helicopter has taken off normally, flown, and landed at the extreme end of the runway." Should we limit fixed wing aircraft to a certain 'rate of ascent' also? That's the beauty of a helicopter, YOU CAN GO STRAIGHT UP! Why is this a safety issue? Does this mean that fixed wing aircraft are not allowed to pull vertical after takeoff anymore because that is a "high rate of ascent"?
I'll say it again, address the person causing the problems. Don't make ridiculous rules that don't address the true problem.
Hide Signatures
(in reply to Montague)
       Post #: 26
SpitfireMKI
Score: 100
Last Login: 12/2/2007
Status: offline
Jeff, Nope........do a search on Spitfires in the database
Irish- yeah you're right but they need to be reposted.
Albert, I know you are a safety type, I really felt sorry that you had to endure a bully when only looking out for his own good.
Now, as far as heli's go, FSA (Previously HCRC, BTW) has been primarily a fixed wing club. My association with the club began with the Hobby Store in 1997, not as a member in 2000. So I have ' been ' around awhile and have heard how things were done. That's probably longer than most on this thread and ACTIVE FLYING members.
It is tough to mix helis and fixed wing, even in the full scale world. I bet you will find most members of this club tolerate the helicopters. But when they are not being operated properly and safely, the sleeping giant will stir. CBRC banned big aerobatic planes from their field for several reasons, one being they aggravated the body membership. Everything is 120 size and under now. So my advice for the heli pilots is: Tread lightly. Not a threat, just advice. I enjoy bringing my heli from work up to FSA, I would hate to not be able too. But it may come down to this.
When Roger, the Cuban and their croanies tried to throw David and myself out of this club, they were holding secret meetings and listening to tape recorded non-member ' spywitness ' accounts of our activities. I pray that it does not come down to this BS again.
The heli pilot in concern should be dealt with by the rules and bylaws, if he has had a verbal warning, then the next is a written document, if he then fails to follow the posted rules, his membership can be terminated.
The fact that on more than one occasion he has been physically threatening is grounds for immediate dismissal as the club rules read. I know because they were written stemming from an incident between the Cuban and myself. I was verbally very rude to him but with good reason, not known to many, a year later he apoligized for his actions towards me that day. An honorable thing to do in my book.
This is a model airplane club, it is supposed to be fun. The rules that are in place are fairly reasonable, if they are followed, our safety is not compromised.
MT
_____________________________
"What madness ? What secrets ? We Plunder,
All failure, We learn from.... Discovery"
Hide Signatures
(in reply to kregan)
       Post #: 27
RE: FSA Clubhouse - 10/20/2005 7:50 PM
SpitfireMKI
Score: 100
Status: offline
To open a can of worms, the old rule for low passes was " Low passes over the runway centerline and out when the only pilot on the line flying" if other pilots are flying then they are kept out over the tall stuff. (A rule that has been re-implemented but not written, like that "No smoke system rule" .
That low pass rule was modified to slap one person on the wrist, very much like where we are going. I think as Irish pointed out, the rules are already there.
That's what I was getting at previosly: Are these not the same rules already posted ? "
As for Rocket takeoffs and aerobatic T/O's, most F/W takeoffs actually occur on either end of the flight boxes, even those great Snaps into knife edges some hot shot does . But loading blades with negative and then slamming them full positive is just asking for a devestating disaster. Sorry don't agree with that KK. There's a lot of built up energy in those blades.
Having been on the receiving end of an out of control heli three times now (due to malfunctions) , I think I have some ground to stand on.
Yes, we do need to deal with the one individual and soon.......
MT
Hide Signatures
(in reply to SpitfireMKI)
       Post #: 28
RE: FSA Clubhouse - 10/20/2005 8:04 PM
DrDeath
Score: 100
Last Login: 6/24/2009
Status: offline
I think that this boils down to a simple issue of having the individual spoken to by the executive committee. Field Marshal, President and Vice president, oh, we don't really have one since he is never around, never mind. Ok just the field marshal and president then. Anyway, the issue isn't Heli's it is this one heli pilot. This thread is starting to get way out of control. There is the old adage “Guns don’t kill people, people kill people”. This is true with heli’s, in this case heli pilot! I have seen this individual auto rotate with the wind coming at his face at about 8 – 10 MPH. He tore up the snow fence twice. The issue about his flying or concern for safety really isn’t this issue alone, it is a culmination of all of the events that have transpired around this one individual for the last 6 to 9 months. Give this pilot a written warning. We also need to give that old curmudgeon that drives the white pickup truck a written warning too . Today Ralph saw him taxiing into the pits, when Ralph told him about it he started with the same crap he does when anyone chastises him about flying in the pits. This guy is unsafe! He has fallen out while flying flew almost into Keith’s head and others, planting planes in the parking lot etc. I believe it is time to put this issue to rest on RCU and deal with it internally and the club officer level.
Let’s get back to ragging on fellow members about their fictitious stories or bad flying, or loosing to rookies or other more stupid stuff.
DD
< Message edited by DrDeath -- 10/20/2005 8:13 PM >
My Website http://mysite.verizon.net/ldharris84/
Club Site http://www.freestateaeromodelers.org/
Hide Signatures
       Post #: 29
RE: FSA Clubhouse - 10/20/2005 8:05 PM
doggscube
Score: 100
Last Login: 5/16/2008
Status: offline
OK... I'll cross-reference the trademark name. Whenever I end up at airliners.net I get distracted for a while.
This is my current wallpaper.
Jeff
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 30
RE: FSA Clubhouse - 10/20/2005 8:12 PM
Bruno Stachel
Score: 100
Last Login: 6/23/2009
Status: offline
Oh man, I loved that helicopter when I was a kid! I used to run up and down my backyard pushing the button making the blades twirl. The copter is buried in hundreds of feet of trash by now, but I still have the GI Joe figure (the same one in your pic).
quote:
ORIGINAL: Advent
Ok, for the sake of peace on RCU I will post over here.
My take on this heli thing....
Our pit boxes are to close to the shelter, without redoing the whole field
I think the heli guys should walk the aircraft to the center of the field and fly
from a box.
If the Heli had been placed at the center of the field and the pilot forced to
stand in the flight box, I don't believe the flight would have happen...
it was so dark there is no way he would have tried from a safe distance.
Click for fullsize
< Message edited by Bruno Stachel -- 10/20/2005 8:15 PM >
Hide Signatures
       Post #: 31
RE: FSA Clubhouse - 10/20/2005 8:55 PM
BrownOut
Score: 100
Last Login: 5/9/2009
Status: offline
Are you guys hiring I want to work with kelly his job site is cool and so is his new airplane. I will tell you guys this about Helis, I am learning to fly one but it will always no matter what or how good I get with it stay home and I will never bring a Heli to the field. I do have one question though, how can you sneak one in prison because after I kill the dog and cut off my wifes head and completly disfigure my home with this electric marvel I am sure my Irish ass will be locked up for many years............LMAO
Hide Signatures
       Post #: 32
RE: FSA Clubhouse - 10/20/2005 9:06 PM
SpitfireMKI
Score: 100
Status: offline
You know DD, when things get heated you want to play politician, how about giving the Kirkster a run at the head spot ?
SCREW HELICOPTERS !
Heheheheheheheheheheheheeeee !
You got to admit, as dangerous as they are, love to watch em' tear themselves to pieces when they crash
MT
Hide Signatures
(in reply to BrownOut)
       Post #: 33
RE: FSA Clubhouse - 10/20/2005 9:13 PM
BrownOut
Score: 100
Status: offline
Ok I need some input on color and design schemes on my 540 Edge. I got all of the covering off and I am now ready for some covering. I am interested in any ideas that you guys may have and or links to design and color schemes. Thanks guys
Hide Signatures
       Post #: 34
RE: FSA Clubhouse - 10/20/2005 9:23 PM
doggscube
Score: 100
Status: offline
Find some pictures of a full-scale. That's what I did with my small Corsair, I sat down with the decal sheet and Google image search until I found one that I could replicate with the decals on hand. Is this the electric or a larger one?
I wouldn't worry about your heli. It's not so much the crashes but the reckless flying and belligerent attitude behind them that are the problem. If I ever end up with one of those E-flite Blades I'll bring it to the field.
-Jeff
< Message edited by doggscube -- 10/20/2005 9:26 PM >
Hide Signatures
       Post #: 35
RE: FSA Clubhouse - 10/20/2005 9:33 PM
DrDeath
Score: 100
Status: offline
Don't want the job or the headache . Besides, I would be a real @$$ as President. I would have kicked the old fart out when he insulted me , so I called him a curmudgeon. Dumb @$$ didn't even know what it was and he was insinuating I was stupid because of my race! If he wasn't old I would have threatened him like the heli guy did our pres. .
I help the club in other ways, event fly ins, website (the original one) and safety officer. I don't want the responsibility of head honcho cause I would start leaning toward a board like PGRC and DCRC. I am starting to think that it has some merits. It would be the only way some things would get done. Nothing against the present body I think that they are doing a lot of good things, but they still have to go in front of everyone for approval. Perfect example is the rolling of the field. If there was a board, they would just deem that the field needs it and do it. No debate, no question. Or, when I did the fly in, we had to vote on that. The board would just say we are having a fly in and who wants to help.
Just starting to think differently on the idea.
Hide Signatures
       Post #: 36
RE: FSA Clubhouse - 10/20/2005 10:17 PM
kregan
Score: 100
Status: offline
Go to the wild hare forum.... Tom just did a design contest and
some really nice stuff was posted.
quote:
ORIGINAL: Spirit In The Sky
Kelly
B.A.C.C. on the road again.
Hide Signatures
       Post #: 37
RE: FSA Clubhouse - 10/21/2005 12:05 AM
DrDeath
Score: 100
Status: offline
How about this scheme
Click for fullsize
Hide Signatures
       Post #: 38
RE: FSA Clubhouse - 10/21/2005 2:59 AM
kregan
Score: 100
Status: offline
Mike T. can you name the location?
Click for fullsize
Kelly
Hide Signatures
(in reply to DrDeath)
       Post #: 39
RE: FSA Clubhouse - 10/21/2005 3:04 AM
kregan
Score: 100
Status: offline
Some more pictures for the wall....
My Mustang before the restoration at a car show, and present
waiting for paint on the rotating stand.
I designed the tilt front end using covertable hydrolics.
I built the rotating stand out of 2 motor stands.
Click for fullsize
Click for fullsize
Click for fullsize
Kelly
Hide Signatures
       Post #: 40
RE: FSA Clubhouse - 10/21/2005 3:08 AM
kregan
Score: 100
Status: offline
One more thing before I go....
Can anyone tell us who has this plane????
Click for fullsize
Kelly
Hide Signatures
       Post #: 41
RE: FSA Clubhouse - 10/21/2005 12:41 PM
Strawhat Mike
Score: 100
Status: offline
quote:
ORIGINAL: Advent
Picked up one of these the other night, it was on my doorstep today...
http://www.swanyshouse.com/mojo/mojo.html
In other news I have the Showtime finished, but not flown...
For somebody who likes pattern and IMAC and not 3D, you're sure accumulating a hangar full of extreme 3D models. In any case, they're not warbirds and will be dismissed by some as simply "aerobats." Welcome to the west side of the tracks.
-- Mike
Hide Signatures
       Post #: 42
RE: FSA Clubhouse - 10/21/2005 3:04 PM
kregan
Score: 100
Status: offline
There is a method to my madness....
Combat planes = combat
Patriot = Speed Plane
Mojo = fun wind plane and 3D
Showtime = set up for pattern
Wild Hare Extra 28% = IMAC
Radio Craft Extra 35% = Just plain sweet. I finaly have the whole plane,
the fuse showed up yesterday and it is really nice. Contest grade balsa
all around, and the fit and finish looks like someone that really cared scratch
built it.
That is what I love about flying... get bored with one type of flying and you
can fly something totaly different.
quote:
ORIGINAL: B. Wildered
quote:
ORIGINAL: Advent
-- Mike
Kelly
Hide Signatures
(in reply to Strawhat Mike)
       Post #: 43
RE: FSA Clubhouse - 10/21/2005 3:34 PM
doggscube
Score: 100
Status: offline
My newest kit is an old Circus Hobbies Reed Falcon that I picked up from our treasurer for a ridiculously low price. It will be quite the departure from the Sig SE kit: no plans, no jig tabs on the ribs. I'm going to read the instructions through a few times to decide if I want to make it my winter project. If I do, it will be done right: fabric covering, a nice Saito, pull-pull rudder.
Any advice on building the wing?
-Jeff
Hide Signatures
       Post #: 44
RE: FSA Clubhouse - 10/21/2005 7:38 PM
SpitfireMKI
Score: 100
Status: offline
Kelly,
Uuuuggggghhh........Oh I really need to think on that one, Fox ferry ? Love that place ! Many tourney's won there ! Hey anytime you need a buddy to go out, give me a shout. I'll give you my number next time I see you !
Nice 70, what's under the bonnet ? The 69-70 coupe had lots in common with the 69-70 Cougar. I'll try to get a pic of mine posted. I had a mild 351W, solid cam, rollers, ported exhaust, TRW's, 3200 stall, 4.11's w/mini spool. Best was a 12.74 @ 107mph. She'd go faster but I wanted it to last so instead of shifting at the redline of 7400, I chose 6000.
How about a warbird edge 540 ? Those US Mustangs were colorfully gaudy !
MT
Hide Signatures
(in reply to doggscube)
       Post #: 45
RE: FSA Clubhouse - 10/21/2005 7:48 PM
SpitfireMKI
Score: 100
Status: offline
Jeff,
Easy ! Build it straight !
Mike, you're right and wrong ! Warbirds are really cool, but you are missing my focus; SCALE Birds With Aerobats, seen one seen em' all,
My boss always tells me "Nothing wrong with an easy flying plane" Yep, I know ! I just like the challenge of a plane that is cantankerous (spell ?) and needs a little more to make it talk. Plus, I get to research, paint, and detail it. In addition, I get passionate about the history of the plane and it's pilot and that satisfies my history buff side.
Aerobats are all about flying perfect and doing perfect manuevers, I see it as the more left brain side of flying. Very mathmatical, and that's fine. To each his own.
Now as for hovering fixed wings, what the hell ?, get a helicopter !
Don't worry, in a few weeks I'll eat my own words on that one, you'll see....
MT
< Message edited by SpitfireMKI -- 10/21/2005 7:49 PM >
Hide Signatures
       Post #: 46
RE: FSA Clubhouse - 10/21/2005 8:29 PM
BrownOut
Score: 100
Status: offline
DR. Death please at the next meeting come forward for your punishment..........LMAO......... How about this scheme
Click to see fullsize image. Gee Wizz and I thought you would come up with something really cool like maybe monokote with lill Helis all over it...................
Hide Signatures
       Post #: 47
RE: FSA Clubhouse - 10/21/2005 8:38 PM
DrDeath
Score: 100
Status: offline
I was wondering when you were going to come on and get a little laugh!
Hide Signatures
       Post #: 48
RE: FSA Clubhouse - 10/21/2005 9:10 PM
Strawhat Mike
Score: 100
Status: offline
quote:
ORIGINAL: Advent
I don't know -- think I'll go out and find her and try to bring her home. Never should have let her leave. She's apparently been passed around from stranger to stranger and they've all had their way with her. Hope she's alright and hasn't contracted anything.....
-- Mike
Hide Signatures
       Post #: 49
RE: FSA Clubhouse - 10/21/2005 9:13 PM
BrownOut
Score: 100
Status: offline
Oh I have been laughing alright this is just what happens when it rains and grown men can't fly......I must have seen it a thousand times.
The only thing FSA needs is some great weather and guys with something to fly out there having fun. My word fellas can't we all just get along......LOL.
Hide Signatures
       Post #: 50
Jump to:
Google
SITE MAP!   : :   FORUM RULES
2.156RCU1
