e-station bc6 charger
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> Common Sense RC Support >> e-station bc6 charger
Page: [1]
Login
e-station bc6 charger - 7/13/2008 8:54 PM
liquidwater
Last Login: 1/2/2009
Status: offline
quick question, if anyone has this charger or have used it before. i will be using 8.4 volt 7 cell nimh batteries. but i read that u can only discharge them at max with this charger .6 amps. my question is. how long would it take to discharge the battery at such little power and is it ok to discharge with such little amps. or should i look into a different charger that has up to 5-10amp discharge?
thanks. peter
Hide Signatures
       Post #: 1
RE: e-station bc6 charger - 7/13/2008 9:40 PM
Red Scholefield
Last Login: 6/24/2009
Status: offline
Circuity do dissipate a lot of watts costs a lot of money. Nothing wrong with the Max 5W discharging limit. The ony purpose of discharging the pack is to check capacity.
_____________________________
Reds RC Battery Clinic
www.hangtimes.com/redsbatteryclinic.html
Hide Signatures
(in reply to liquidwater)
       Post #: 2
RE: e-station bc6 charger - 7/13/2008 10:31 PM
liquidwater
Status: offline
thanks, i have read that only 600 milliamps of discharge power will take over 6hrs to discharge, is that true?
Hide Signatures
(in reply to Red Scholefield)
       Post #: 3
RE: e-station bc6 charger - 7/13/2008 11:58 PM
Red Scholefield
Status: offline
quote:
ORIGINAL: liquidwater
It depends on the battery. If you have one that is 3600 mAh then it will take that long.
Hide Signatures
       Post #: 4
RE: e-station bc6 charger - 7/14/2008 1:51 AM
liquidwater
Status: offline
the battery i will be using is a ener-G 8.4 volt 4600 mah
Hide Signatures
       Post #: 5
RE: e-station bc6 charger - 8/22/2008 9:39 PM
akz28
Last Login: 6/23/2009
Status: offline
I've read in a review that the 12v inputs are live (hot) when the unit is plugged into an AC outlet. Can someone please confirm if that is true?
< Message edited by akz28 -- 8/22/2008 10:25 PM >
Hide Signatures
       Post #: 6
RE: e-station bc6 charger - 8/25/2008 6:05 PM
Tram
Last Login: 6/12/2009
Status: offline
Yes, that is true.. However, if the leads touch, the unit will shut down without allowing any damage to the unit or the battery packs, etc...
Jeff Williams
www.CommonSenseRC.com
Hide Signatures
(in reply to akz28)
       Post #: 7
RE: e-station bc6 charger - 6/1/2009 2:00 PM
akz28
Status: offline
After using this charger for about a year now, I've been thinking of making an alteration. I would like to get rid of the long 12v leads and either put a much shorter pair of leads with female jacks, or incorprate the female jacks into the unit. That way I can just use a pair of leads that I can plug into the unit when I want to connect to a 12v DC source.
Has anyone ever done this? Are these jacks the same as the audio jacks that you find in the electronics store? If you did put the jacks inside the unit, where did you get your parts from?
Thanks..........................
Hide Signatures
(in reply to Tram)
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.609RCU1
