Duralite Li-Manganese Question
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> Duralite Support Forum >> Duralite Li-Manganese Question
Page: [1]
Login
Duralite Li-Manganese Question - 1/17/2009 11:16 AM
av8rk
Last Login: 6/24/2009
Status: offline
Hello Mark,
I have your Li-Manganese ECU battery....3800 mah 7.4 volt 2-cell 2s1p.....with 14 gage power lead.....The instruction sheet says i can also charge this battery through the power lead if i want to.....So my question is: If i charge through the power lead, doesn't charging this way defeat the purpose of the charge safe circuitry module within the battery?
FYI.....I have both the Duralite charger and a Orbit Pocketlader charger
Richard
Hide Signatures
       Post #: 1
RE: Duralite Li-Manganese Question - 1/26/2009 4:49 PM
DuraliteTech
Last Login: 1/26/2009
Status: offline
Hi Richard,
You can charge through the power output lead at a higher rate (1C +) as the balance circuit will continue to function normally. This allows quick charging and still ensures the pack is balanced.
You can also charge through the yellow charge lead at a maximum charge rate of 1 amp without damaging the circuit.
_____________________________
Mark
Duralite Tech Support
Hide Signatures
(in reply to av8rk)
       Post #: 2
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.234RCU1
