I think the guy at my lhs sold me the wrong charger.
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> Common Sense RC Support >> I think the guy at my lhs sold me the wrong charger.
Page: [1]
Login
I think the guy at my lhs sold me the wrong charger. - 6/19/2009 4:29 AM
Paul103
Last Login: 6/23/2009
Status: offline
 I bought the venom 7.2 1800 nicd battery for my traxxas ezstart. The guy sold me a dynamite mega 1 charger. The venom battery clearly states "Do not trickle charge" and I think thats all that the mega 1 does. Should I try using it and if not which charger should i get?
Hide Signatures
       Post #: 1
RE: I think the guy at my lhs sold me the wrong charger. - 6/19/2009 12:27 PM
guver
Last Login: 10/20/2009
Status: offline
If that is a timer charger then it only trickles after the fast charge and you can pull the batttery as soon as the timer is done if you do not want to trickle. Trickling will not hurt your battery.
_____________________________
good judgement comes from experience
experience comes from bad judgement
Hide Signatures
(in reply to Paul103)
       Post #: 2
RE: I think the guy at my lhs sold me the wrong charger. - 6/19/2009 2:40 PM
Paul103
Status: offline
Yea, I double checked the manual and youre right. The only problem i have now is how to discharge the battery since its a nicd. Its in the ezstart and its at 6.4v and the ezstart motor turns slowly. Can I charge it when its at 6.4? Will it only charge up to 6.4? How do i discharger it? If I try to use it up with the ezstart then it will probably get hot and destroy itself.
Hide Signatures
(in reply to guver)
       Post #: 3
RE: I think the guy at my lhs sold me the wrong charger. - 6/19/2009 10:59 PM
guver
Status: offline
6.4 is already discharged. Can charge and go. I find timer chargers just fine normally , but an easy-start application really needs a peak charger (auto-shut off) becasue it's hard to keep track of how much you've used the starter and you don't want to be caught with it discharged. Witha cheap peak charger you can top it off each time and it'll shut off when the pack is full. If you can get by with runnig the starter all the way down each time then you can easily estimate it because you will know when it's empty (like it is right now running slow)
Hide Signatures
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.359RCU1
