Reload this Page >
Maj. Woody's Ultra Flash
Old 03-25-2017, 10:28 AM
  #251
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
With the canopy secured over the frame, I used 3M fine line tape to mark the location of the frame on the canopy. I then removed the canopy from the frame and cut it to size using my dremel tool.
ID:	2206979   Click image for larger version
ID:	2206980   Click image for larger version
Old 03-25-2017, 10:31 AM
  #252
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
Next I covered the top of the canopy to protect it from scratches as I do the final fitting. As you can see my initial trimming was still too big to fit inside the frame.
ID:	2206982   Click image for larger version
Old 03-25-2017, 10:38 AM
  #253
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
I put the canopy back over the top of the frame and held it in place with rare earth magnets. This is a great tip I picked up from someone in Dave's Thread! I then used a light to roughly mark the outline of the canopy frame on the canopy. After several fittings and trimmings I had a perfect fit of the canopy inside the frame. I then used a pen to trace the exact outline of the frame on the canopy. I then applied 3m fine line tape around that pen line.
ID:	2206984   Click image for larger version
Old 03-25-2017, 10:40 AM
  #254
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
Use a razor and cut the painters tape away following the fine line tape. Once removed you can sand the canopy with 100 grit sandpaper in preparation for gluing.
ID:	2206986   Click image for larger version
Old 03-25-2017, 10:43 AM
  #255
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
Sand the inside of the canopy frame with 100 grit also and be sure to level out the glass tape seams and glue blobs. Clean the frame and canopy with alcohol when complete.
ID:	2206988   Click image for larger version
Old 03-25-2017, 10:47 AM
  #256
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
Gather up everything you will need for gluing the canopy to the frame. I used Pacer canopy glue, hot water, Q-Tips, paper towel and some plastic safe paint thinner and dozens of rare earth magnets.
ID:	2206990   Click image for larger version
Old 03-25-2017, 10:50 AM
  #257
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
I used a generous amount of glue along the canopy frame. Once in place with the magnets, I spent a considerable amount of time with the hot water, Q-Tips, paper towels and thinner cleaning up the canopy.
ID:	2206992   Click image for larger version
Old 03-25-2017, 10:54 AM
  #258
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
I then mounted the canopy to the fuse and installed the retaining rod. I will let this dry till tomorrow then give the canopy a final detail cleaning and polish. Doing this job sucked!
I am planning to use the stock cockpit pieces as a starting point but adding some extra detail like a scratch built panel, buttons and some other details. I hate this part but like how it looks when its done.
ID:	2206995   Click image for larger version
Old 04-02-2017, 05:58 AM
  #259
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
I marked off the molded cut lines and used a cutoff wheel to roughly trim the cockpit parts.
ID:	2208064   Click image for larger version
ID:	2208065   Click image for larger version
ID:	2208066   Click image for larger version
Old 04-02-2017, 06:01 AM
  #260
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
I have something different in mind for the panel so I marked off the glare shield and cut the panel out. I traced the outline on some scrap balsa and then mocked up a panel that will serve as a template.
ID:	2208068   Click image for larger version
ID:	2208069   Click image for larger version
ID:	2208070   Click image for larger version
Old 04-02-2017, 06:04 AM
  #261
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
Using my balsa template I then cut the actual panel out of plastic purchased at the local hobby shop.
ID:	2208072   Click image for larger version
Old 04-02-2017, 06:09 AM
  #262
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
I tacked glued the glare shield in place then spent I spent a lot of time trimming to get all the cockpit parts to fit properly. Once things fit to my liking, I tack glues the panel to the cockpit tub. I used some spot putty to smooth things out a bit.
ID:	2208074   Click image for larger version
Old 04-02-2017, 06:15 AM
  #263
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
Next I did the final shaping of the panel and cockpit tub. Once complete I glassed the two pieces together. The tub and panel are now one unit and slide into the canopy frame together and fit snugly against the previously installed (tacked at this point) glare shield. As you can see from this bottom view that once I permanently glue everything together this will become a one piece affair.
ID:	2208076   Click image for larger version
ID:	2208077   Click image for larger version
ID:	2208078   Click image for larger version
ID:	2208079   Click image for larger version
ID:	2208080   Click image for larger version
Old 04-02-2017, 06:18 AM
  #264
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
I fit my pilot to the tub which required some trimming of the tub. I then cut out the included seat and test fit it. I really did not like how this looked so again.....off to build something different.
Old 04-02-2017, 06:20 AM
  #265
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
Based on some pictures of ejections seats on the internet, I mocked up a fun scale seat using balsa.
ID:	2208083   Click image for larger version
ID:	2208084   Click image for larger version
Old 04-02-2017, 06:21 AM
  #266
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
As with the panel, I used these balsa templates and cut the seat parts out of plastic.
ID:	2208086   Click image for larger version
Old 04-02-2017, 06:23 AM
  #267
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
Here are various views comparing my seat to the stock seat.
ID:	2208104   Click image for larger version
ID:	2208105   Click image for larger version
ID:	2208106   Click image for larger version
Old 04-02-2017, 06:26 AM
  #268
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
Here is what it looks like next to my pilot. I think this is going to look really nice after I add the additional details such as rocket rails, chute details, paint and decals.
ID:	2208092   Click image for larger version
ID:	2208093   Click image for larger version
ID:	2208094   Click image for larger version
Old 04-02-2017, 06:31 AM
  #269
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
I made a HUD from some plastic Bean purchased for the Hobby Shop and the top of a Futaba servo package.
ID:	2208096   Click image for larger version
ID:	2208097   Click image for larger version
Old 04-02-2017, 06:33 AM
  #270
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
After wet sanding the glare shield with 400, I glued the HUD in place. I then masked the areas of the HUD that wont be painted. The glue joints will be hidden by the paint.
ID:	2208099   Click image for larger version
ID:	2208100   Click image for larger version
Old 04-02-2017, 06:36 AM
  #271
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
And now a few coats of flat black paint. It hard to believe but I have over 28 hours invested in doing the cockpit and canopy at this point. I know this seems extreme but it takes me hours to design things like the seat and then make the patterns by trial and error.
ID:	2208102   Click image for larger version
Old 04-03-2017, 08:53 PM
  #272
wblombard
Wow!! Attention to detail is sick! Great Job! Looking forward to see your avionics install, that must be sick.
I'm 2% away from maiden...getting excited and nervous
Old 04-04-2017, 08:34 AM
  #273
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
Thanks for the compliment! Good luck with the maiden. Please let us know how it goes.
Old 04-04-2017, 11:50 AM
  #274
Instructor
My Feedback: (16)
Instructor's Avatar
Hi Dom,
Looks like we think alike. Here is a photo of my Turbinator cockpit that I built two years ago.
Larry/Instructor
Old 04-04-2017, 12:52 PM
  #275
scoeroo
My Feedback: (9)
scoeroo's Avatar
That's neat -
