Reload this Page >
Maj. Woody's Ultra Flash
Old 11-13-2016, 05:31 PM
  #51
Gary Jefferson
My Feedback: (167)
Dom it is good to see you are back. I am building an ultra flash right now myself.
Old 11-14-2016, 09:56 AM
  #52
warbird_1
My Feedback: (61)
warbird_1's Avatar
Originally Posted by MaJ. Woody
On Marks recommendation I purchased one of the Scratch and Dent Pilots from Dreamworks. It had some minor peeling of the decal on the helmet (hence the scratch and dent sale) but that was no concern to me as this pilot "made the Team" and was getting new threads!
Dom, i thought for sure you'd use the major woody signature series pilot ...
Old 11-14-2016, 03:03 PM
  #53
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
Hi Gary.
Great to hear from you! I saw your old BARF Fly at Titusville several weeks ago. I had my eye on that when it was for sale. What scheme is your UF? I hope to see you at a Jet Meet next season.
Old 11-14-2016, 03:05 PM
  #54
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
Holy $h!T Griz I am LMAO with this one!!
Old 11-15-2016, 11:37 AM
  #55
RCISFUN
My Feedback: (44)
RCISFUN's Avatar
YIKES... I am having nightmares now
Old 11-15-2016, 01:08 PM
  #56
smiller
Me Too !! Lol !!
Scott
Old 11-15-2016, 02:48 PM
  #57
causeitflies
causeitflies's Avatar
Trying hard to unsee that picture
Old 11-15-2016, 04:01 PM
  #58
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
Wow I forgot how much fun you guys are! Cant wait to fly with everyone next year!!
Old 11-15-2016, 05:43 PM
  #59
RCISFUN
My Feedback: (44)
RCISFUN's Avatar
Mark its too late, you can not un-see that image!
Old 11-26-2016, 03:45 PM
  #60
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
I did some work on my gear today. Here is the Pro-Link Nose strut and Intairco wheel out of the box.
Old 11-26-2016, 04:08 PM
  #61
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
I used a sharpie to mark where the set screws that secure the steering pin to the strut are located. A flat spot is needed for these set screws so the strut and steering arm do not twist under load. Disassemble the steering arm and bearing and file a flat on the steering pin. I make my initial cuts with a Dremel tool then square off the edges with a flat file. Be sure to file flats for both the front and rear set screws.
ID:	2191347   Click image for larger version
ID:	2191348   Click image for larger version
Old 11-26-2016, 04:11 PM
  #62
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
Mark the set screw locations for the steering arm next and file flats for both set screws.
Old 11-26-2016, 04:14 PM
  #63
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
I used a tapered cutter to clean up the top of the steering bearing. This ensures smooth operation between it and the steering pin.
ID:	2191351   Click image for larger version
Old 11-26-2016, 04:17 PM
  #64
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
Time to assemble everything using Loctite. If you were precise when grinding your flat spots, everything will be square when you tighten all of the set screws.
ID:	2191353   Click image for larger version
Old 11-26-2016, 04:19 PM
  #65
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
Next I removed the bolt inside of the strut and reassembled it with Loctite.
Old 11-26-2016, 04:25 PM
  #66
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
Next I removed all of the screws holding the wheel halves together and then reassembled them with Loctite. I opted not to use the nylon material supplied to make the spacers for the nosewheel but used a set of custom sized wheel collars instead. The Nosewheel and spacers were then assembled with Loctite.
ID:	2191356   Click image for larger version
ID:	2191357   Click image for larger version
ID:	2191358   Click image for larger version
Old 11-26-2016, 04:29 PM
  #67
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
I removed each screw in all three retracts and reinstalled them using Loctite. This proved to be unnecessary since they came from the factory with Loctite. This is the first set of retracts in my 35 years of modeling where this important step was performed by the factory. Still I had to redo them all to ensure none were missed by the factory. None were!
Old 11-26-2016, 04:32 PM
  #68
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
The music wire used to center the strut was too long for my taste so I cut them down a bit.
ID:	2191361   Click image for larger version
Old 11-26-2016, 04:42 PM
  #69
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
Now to disassemble the main Struts. The springs on the struts are slightly stretched when the struts are fully extended so its important to disassemble them in the proper order to avoid damaging the screws or struts. First remove the C Clip as shown. Next put the strut in a vise. Now you can relax the spring pressure while removing the lower pivot bolt. Back on the bench you can safely remove the upper spring retaining bolt followed by the lower spring retaining bolt.
ID:	2191363   Click image for larger version
ID:	2191364   Click image for larger version
ID:	2191365   Click image for larger version
ID:	2191366   Click image for larger version
Old 11-26-2016, 04:47 PM
  #70
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
Now reassemble everything in the reverse order using Loctite on all the bolts. Also shown in this photo is the main wheel. Note that the screws securing the main wheel halves are T-8 Torks screws. Put all of those back in using Loctite as well.
Old 11-26-2016, 04:53 PM
  #71
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
Cut the main wheel axles to length. Be precise here making sure the overall length gives you a slop free assembly without excess drag on the wheel. Mark the location of the set screw and file a flat on the axle.
ID:	2191369   Click image for larger version
ID:	2191370   Click image for larger version
ID:	2191371   Click image for larger version
Old 11-26-2016, 04:59 PM
  #72
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
Although I use a proportional brake valve, I always use a thin film of Polysi on my brakes to prevent them from locking up. I had previously used grease but one of you recommended the Polysi to me at one of the Jet rallies. Polysi is both slippery and sticky so it wont fling all over. Put the brake and wheel assembly on the strut and secure the set screw with Loctite.
Old 11-26-2016, 05:06 PM
  #73
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
Here is the completed Gear Package ready for installation. So far I am very impressed with the quality of the gear. The struts are very beefy, have tight tolerances and are beautifully finished. The retracts are very strong as well and the mechanics are super smooth. I have not pressure tested them so I don't know how well they hold air yet bet I suspected they will be leak free. I will be installing my Tamjets Gear Failsafe as an extra measure of security.
Old 11-26-2016, 05:08 PM
  #74
MaJ. Woody
My Feedback: (28)
MaJ. Woody's Avatar
Well at this point I am truly out of things to do till the airframe gets here. I think I will call Linda next week and see if she has an ETA on the "Boat".
Old 11-26-2016, 05:46 PM
  #75
RCISFUN
My Feedback: (44)
RCISFUN's Avatar
I have suggestion, make a direct drive steering modification, here is a link to my modification I made back in 2009, since then I made a few improvements, once you go direct drive steering you will never want a pull pull cable system again.
see post #118 for the basic idea
http://www.rcuniverse.com/forum/rc-j...rebuild-5.html
