Why Futaba does not offer BNF?????
RE: Why Futaba does not offer BNF?????
I was pretty certain that futaba and kyosho would get together and do their own range, so far i have been proved wrong though.
I opted to go with the Spektrum DM8 module for my trusty old Futaba 8UAF, but
I'm not sure I made a good choice. After binding the module to an AR7000
reciever, the servos "shake" or constantly "vibate". Same thing happened
when I tried it in my Parkzone Wildcat with the AR500 reciever. Horizon's tech
guy says they will replace the module. Any ideas before I send it back?
#32
I have had a Spektrum Module installed in my XP9303 for several years. I use it with a couple of AR9000's, several AR6100's, and an AR7000.
Are you using a 6v Rx battery? If so, are the servos rated for 6v?
The other issues I have had with Shaky servos have been the result of using cheap Y Harness and extensions. I prefer to use Extensions and Y Harness's of at least 20ga-22ga. I really avoid using a Y Harness at all because I have had more problems with them than any other issue.
#33
Looking at the Futaba webpage it mentions at the 2.4FHSSdrop downmenusomething about "FTR"(Futaba Transmitter Ready) aircraft. Are these the BNF from Futaba??? When are these planes going to be available for sale?? I'm ready to jump to a DX7-DX8 but Iwould like to give Futaba a chance............
#34
This is an old thread, but your catching that detail is very interesting, first time I've heard of FTR[8D]
I certainly hope that the FHSS update is released for the 8GH!!
Here's the link for anyone interested.
http://www.futaba-rc.com/technology/fhss.html
Pete
Pete
#35
ORIGINAL: TimBle
However, what seems like a good idea has a downside. Each BNF and PnP model is an additional stock keeeping unit (SKU). Each of those has to have a home from marketing all theway through to planning, manufacturing, packaging and distribution, warehousing and sales reporting.
Each of those SKU's needs to be managed for P&L and also needs to fit into the companies marketing strategy.
To support a BNF type of product would mean Hobbico will require Futaba's complete commitment to the parkflyer market and that is an area that Futaba is only now starting to push into.
#36
1 Post
FTR is likely the Futaba / Hobbio BNF type product. Been over a year since this discusson got off the ground (pun intended).
A birdie whispered in my ear last year that this was on the way and that it wouldhave features not yet seen in this market. Well I guess its almost here , ...maybe maybe not
#37
BNF is great for those just starting off in this. Once you have a few planes and helis and can fly, then it's time for the real stuff! The problem I found with PNP or RxR planes is the cost to add the RX and batteries exceeds the cost of the BNF version. If you do what I did, get planes that use the same packs, then it is a more feasible approach.
#38
ORIGINAL: acdii
Many of these aircraft are not just for beginners, in fact the Warbird series requires an experienced pilot.
#39
BNF is certainly not just for beginners - We have a group of indoor fliers who love this stuff and we all have or had stuf up to 42 % - contest scale - F1 racers- Pattern flyers ,IMAC TOC -you name it
Bind n Fly is fun and that's why they sell like the proverbial hotcakes.
Futaba will likely get into the game - now that they have a radio series which should adapt it's self to the miniature systems (much like the 6400 rx from Spektrum)
Hobbico obviously sees the size of this market and want's to be a player
Can't blame em and it remains to be seen how well they do at it.
#40
I do not think Futaba will be doing this directly. I suspect that it will be done by Great Planes with the blessing of Futaba to use their equipment and name in the marketing.
#41
KY
So will I be able to use my 6EX if and when BNF becomes abailable? Or will it be outdated as my DX6 is? I'm concerned that we're about to enter a game where transmitters will need to be replaced a bit more often than I would like.
#42
Probably not. The FTR seems to be FHSS and that leaves the 6EX and 7C out of the game. They already do have an FHSS conversion module for those radios that are module based.
Pete
Pete
#43
My Feedback: (19)
I'm really hoping Futaba comes out with an update for the 8FG/12FG/12Z/14MZ/18MZ that allows a software selection to transmit on either FHSS or FASST. That would open up a whole new world of foamies and micro planes that are similar to the BNF stuff I'm now flying with a Spektrum DX7.
#45
ORIGINAL: Bruno Stachel
I'm in the same situation. I'm currently flying the 6EX(been great with no problems so far)but from the information Ihave gathered from other forums the 6EX and 7C will be become dinosaurs very soon. Ithink if these FTR's airplanes become available soon one option is to get a Futaba 6J or wait for the 8J. The other Futaba radios will be in the upper leagues..............If not the DX's are readily available.........
#46
ORIGINAL: BuschBarber
Bind and Fly aircraft, such as Parkzone, come with all the components installed and Ready to Fly. That includes Rx, Servos, Batteries, ESC, and Motor. It is the Plug and Play versions that require the additional expense and installation time.
ORIGINAL: acdii
BNF is great for those just starting off in this. Once you have a few planes and helis and can fly, then it's time for the real stuff! The problem I found with PNP or RxR planes is the cost to add the RX and batteries exceeds the cost of the BNF version. If you do what I did, get planes that use the same packs, then it is a morefeasible approach.
#47
ORIGINAL: acdii
Um, I do believe that is what I said.
ORIGINAL: acdii
#48
Sorry!! I must have suffered a Brain Cramp.
ORIGINAL: acdii
ORIGINAL: acdii
Oh BTW, I didnt mean it to sound as if it was only for beginners, I meant it was good for someone who has nothing, and can have an easy way to get started with hardware. If you are already an established RC'r and have radios already, it isnt so good unless you have a Spektrum radio that works with them.
Igood way to get started is with a RTR that has something like a DX6i in it, but those that have FM radios are not so good to start with.
It just dawned on me, with my last purchase, I now have nearly $4K invested in this stuff this year. Most of it BNF, only the Apprentice was a RXR, the T-34 was RTF, the rest BNF. My latest plane is under construction and instead of getting another Spektrum RX, bought a Futabe 8FG Super with 2 RX. I'm lazy, rather buy a radio and RX that fits the plugs on the Servos, than make the plugs fit the RX Ialready have. LOL
#49
ORIGINAL: acdii
Po Noblem, had me scratching my head there for a few minutes.
I good way to get started is with a RTR that has something like a DX6i in it, but those that have FM radios are not so good to start with.
It just dawned on me, with my last purchase, I now have nearly $4K invested in this stuff this year. Most of it BNF, only the Apprentice was a RXR, the T-34 was RTF, the rest BNF. My latest plane is under construction and instead of getting another Spektrum RX, bought a Futabe 8FG Super with 2 RX. I'm lazy, rather buy a radio and RX that fits the plugs on the Servos, than make the plugs fit the RX I already have. LOL
ORIGINAL: acdii
ORIGINAL: acdii
#50
Agreed, I have one in the T-34 and plugging in the wing is a PITA, and that is with Eflite servos! I guess tight is better than loose though.
I started reading the Futaba manual, had to put it down, my eyes crossed. Man can that radio do a LOT.
