g-5 russian torpedo boat
RE: g-5 russian torpedo boat
Hi Guys
the G-5 is back on the bench after a long break. just got feed up with rivets. I will have it in the water this spring. also ran across this cool russian torpedo boat. Craig
http://walkarounds.scalemodels.ru/v/...ets/?g2_page=1
Hi Guys
here is a good source of plans for the G-5. you can get this paper model from the paper model store. if you try to use the Armada plans you will see they are full of bugs. nothing lines up. that is all i had to use when I built mine. Craig
#31
How is this build going? Been doing a bit of research on this myself as there is a company in the UK that produce a 1/25th hull. Really liked the look of it. Looking forward to working out how to launch and drive the torpedoes, that will be fun. Would you be good enough to point me in the direction of plans, may just decide to build my own hull. Any help much appreciated.
Colin
Colin
#42
Looks nice!
#44
Hello, after years i start to draw and build Torpedo boat G-5 can you share with me your design? Thanx. My email Is [email protected]
