Reload this Page >
Top Flite Giant Scale Spitfire ARF
Old 10-13-2013, 01:56 PM
  #301
kahloq
kahloq's Avatar
So I was thinking of making a mount made from plywood and silicone tube( for soft mounting the muffler). Something like that could be used on the pitts can part of the wrap around muffler to hold that side. No welding required. The silicone tube would be tight enough to prevent vibration, but not so tight you couldn't slide the muffler can out if you needed to remove the muffler from the engine. The plywood mount with hole for the can would be hard mounted to the firewall or front fuse structure. This should prevent vibration stress on the muffler bolts.
Old 10-14-2013, 03:59 AM
  #302
dasintex
My Feedback: (10)
dasintex's Avatar
Originally Posted by SWORDSN
Dasintex, How many flights do you have on this engine muffler combo?
So far so good no problem, several flights!
Old 10-14-2013, 04:01 AM
  #303
dasintex
My Feedback: (10)
dasintex's Avatar
Originally Posted by Warbird AL
Great idea, I have lost 3 mufflers from them cracking and or breaking at the manifold. I will have to look up how to weld aluminum,
I actually took my Muffler to a welding shop, I made the braces, showed them where to place them and weld them.
Old 10-14-2013, 04:06 AM
  #304
dasintex
My Feedback: (10)
dasintex's Avatar
The only problem I can see is that the Engine and Muffler Vibrate together and separate from the Firewall; I was told that you need to anchor the Muffler to the Engine or Engine Mounts, not to the firewall because of the difference and independant movement of the Engine and Firewall, but your Silicone tube may provide a cushion to baffle that difference or variance in movement between the Engine and Firewall. Guys that use those Long Cannisters and headers, use a piece of Silicone Tube to join the Muffler to the Header as the Muffler is mounted solidly to Fuselage.
Old 10-14-2013, 06:41 AM
  #305
radfordc
My Feedback: (14)
radfordc's Avatar
You don't have to weld. I did mine like this: http://www.troybuiltmodels.com/ns/learn/pittsbracket/
Old 10-14-2013, 06:44 AM
  #306
radfordc
My Feedback: (14)
radfordc's Avatar
I guess that could be a problem in some cases, but it hasn't shown up in my plane yet. I have a DLE 55 in a P-40 with 50 flights so far.
Old 10-25-2013, 04:07 PM
  #307
kahloq
kahloq's Avatar
Slowly plugging away on mine. Using an EME55 with electric starter. It barely fits(the starter). I will need to add a reinforcement on the inside of the cowl next to where the electric starter is to prevent rubbing damage(if such occurs) while the motor is running causing stuff to vibrate around.
Anyway....installed a Jtec tapered wrap around muffler(tower lists it for p-51.....not the same one as for a p-40).
Friend of mine had his out to the field the other day and would have tried to maiden, but found his flap servos were going south.
Please note.....the HobbyKing retracts for their Spitfire fit this Top Flite Spitfire almost dead perfect. Only enlarging a couple bolt holes was required. My gear from the HK Spitfire survived the catastrophic wing failure so that saved me some money. My friend also used the HK spitfire retracts from his HK plane(his went smush as well....but was pilot induced)
My TF spit is now primer painted after recovering the thing with solartex. Hopefully I can get it done in a few weeks before the weather goes absolutely to crap.
Not much to show really currently as its all in grey primer, but if someone wants, I can snap a photo or two.
Old 10-25-2013, 06:38 PM
  #308
DUCATIKID
Hi kahloq, was it hard to get the covering off? did you leave the control surfaces on? look forward to seeing what it looks like when its finished
Old 10-25-2013, 07:03 PM
  #309
kahloq
kahloq's Avatar
The covering was pretty easy to get off. I pulled it off without the need of any tools. I did leave the control surfaces on and worked around them. I applied solartex to replace the crappy monocote. Im not the best at applying covering, but I did ok...looks a ton better then out of the box even in just primer color. I used neutral solartex as that will take any color paint, however, aluminum solartex is a bit stiffer as it has aluminum of some kind impregnated in it. That's also good for being able to weather it later on...say painting the plane whatever color and scratching areas off
Old 10-26-2013, 06:34 AM
  #310
Ramstein44
My Feedback: (157)
Ramstein44's Avatar
Yeah, Kahlog, lets see the spit.. I need some motivation to work on mine..
Old 10-26-2013, 09:28 AM
  #311
Chris Nicastro
Chris Nicastro's Avatar
On the DLE 55RA muffler problem... Mine blew out the welds also at about the 30th flight. I took it to a local welding and fabrication shop and got it fixed for $20. Its not pretty but it works. I need to deck the manifold flat and mount it but for the quick turn around it should be worth it.
Otherwise, love the engine
Old 10-26-2013, 02:40 PM
  #312
kahloq
kahloq's Avatar
ill get some pics as soon as I can.....I'm taking part in wife's haunted house at her work tonight in Cheyenne. ironically....I'm playing the part of a dead German pilot zombie
Old 10-27-2013, 07:45 AM
  #313
kahloq
kahloq's Avatar
Well....here's "Walking Dead" Kahloq at wifes haunted house event
ID:	1933548   Click image for larger version
Old 10-27-2013, 08:57 AM
  #314
kahloq
kahloq's Avatar
Spitfire in progress pics.
Not much to show as stated. Motor installed, jtec wrap around muffler(had to relieve part of the cowl mounting block where the end of the canister is on opposite side). Electric starter, etc.
The other pics show fuse hatch for switches, air fill. The hatch is in the scale spot for the pilot egress door. I put the switches face up so I could look into the canopy while everything is buttoned up and see LED voltage readings.......plus, it was the least invasive space wise in the cockpit. Almost looks like they belong there as part of the gauges and stuff in the cockpit anyway.
ID:	1933573   Click image for larger version
ID:	1933574   Click image for larger version
ID:	1933575   Click image for larger version
Old 10-27-2013, 12:06 PM
  #315
Warbird AL
My Feedback: (10)
that's one hell of a nose bleed
Old 10-27-2013, 01:45 PM
  #316
glazier808
glazier808's Avatar
I think it might've been something you ate...
Casey
Old 10-27-2013, 02:27 PM
  #317
JL1
My Feedback: (93)
Opinions are like belly buttons, everybody has one. There is no future in getting your Knickers in a knot over any of them.
Old 11-08-2013, 06:14 PM
  #318
WarbirdPilots
My Feedback: (209)
Default RAF Spitfire Pilot from www.warbirdpilots.com
Hey Guys,
Its Adam from WWW.WARBIRDPILOTS.COM and Just wanted to show all the spitfire enthusiasts the most recent updated version of my 1/5~1/6 Scale 12" RAF Spitfire Pilot.
I updated the uniform to a Royal Blue uniform with new life vest and Parachute Pack. It more accurately resembles what a Spitfire Pilot wore during combat. I have sold a bunch of these to Top Flite owners and they fit great in the new Giant Spitfire ARF.
As you can see they are fully articulating with the ability for every joint to move. And only weigh 8 ounces. The pictures of the pilot in the plane is the old Spitfire Pilot version in my 88" Pica Spitfire.
If you get a chance, check out this pilot and more than 25 other Pilot Figures at WWW.WARBIRDPILOTS.COM
Adam Martin
Name:	Spitfire Pilot Figure 1.JPG
ID:	1937850   Click image for larger version
Name:	Spitfire Pilot Figure 8.JPG
ID:	1937857   Click image for larger version
Name:	Spitfire Pilot Figure 7.JPG
ID:	1937858   Click image for larger version
Name:	Spitfire Pilot Figure 9.JPG
ID:	1937859   Click image for larger version
ID:	1937860   Click image for larger version
ID:	1937861   Click image for larger version
ID:	1937862   Click image for larger version
ID:	1937864   Click image for larger version
Name:	Spitfire Pilot Figure 2.JPG
Old 11-09-2013, 03:42 PM
  #319
kahloq
kahloq's Avatar
I have the new pilot from King Toys
http://www.timewalkertoys.com/King-s...-p/kt-8003.htm
Old 02-16-2014, 11:36 AM
  #320
tfarmer96
tfarmer96's Avatar
Ok this spit has been done for a while I just got to cg it today. Its nose heavy....is the cg in the book right I cant believe I have a lead free spitfire on my hands
ID:	1969147   Click image for larger version
Old 02-16-2014, 12:07 PM
  #321
Lifer
Lifer's Avatar
tfarmer,
Is there a chance you have pictures of the cuts you had to make in the cowl for cooling air entry and exit?
Thanks in advance!
Old 02-16-2014, 12:21 PM
  #322
tfarmer96
tfarmer96's Avatar
Originally Posted by Lifer
tfarmer,
Thanks in advance!
ID:	1969158   Click image for larger version
Old 02-16-2014, 02:29 PM
  #323
Lifer
Lifer's Avatar
Thank you. It looks like the engine head should keep cool enough and you have milled the slots in the radiator behind it to get rid of residual heat. I had a H-9 Spit that needed a LOT of the cowl removed to keep the engine cool so I was concerned. As well, I would also run an airline for the pump diaphragm cover so it could breath more freely.
I appreciate you taking the time to post the photos. Hopefully, I can return the favor someday.
Old 02-16-2014, 06:12 PM
  #324
tfarmer96
tfarmer96's Avatar
it took 6.4 oz of lead on the tail to balance at the cg in to book. First warbird I have ever had that needed nose weight.
Old 02-18-2014, 06:00 AM
  #325
SWORDSN
My Feedback: (13)
especially a Spitfire!
