Reload this Page >
Top Flite Giant Scale Spitfire ARF
Old 02-18-2014, 07:01 AM
  #326
ronht
Originally Posted by tfarmer96
it took 6.4 oz of lead on the tail to balance at the cg in to book. First warbird I have ever had that needed nose weight.
I just cut one of the nose weights that was included in half and reattached it and the balance came out spot on.
Old 02-26-2014, 01:19 PM
  #327
Lifer
Lifer's Avatar
Has anybody taken any flight videos yet? I am also interested in a detailed flight report/opinion. Thanks in advance.
Old 02-26-2014, 03:31 PM
  #328
ronht
I have about 30 flights on mine. Great airplane flies like it's on rails.
Ground handling is much better than you might expect, no quick turns mind you or you'll be down on a wing-tip, but the tracking with the narrow gear is really fairly easy.
For take-off just slowly advance the throttle until the tail comes up. I'm usually airborne by 3/4 throttle making a scale take-off.
In the air the airplane is just great and does all the expected warbird maneuvers with ease. I'm using a 22/8 prop on my DLE 55 which I like as it provides a good balance between speed and vertical performance. Some guys are using a 22/10 for more flat out speed but they lose quite a bit in the vertical.
The airplane handles slow flight easily, and with these split flaps, you can expect the aircraft to nose down a bit when adding flaps unlike the nose up reaction other planes have.
I've only done wheel landings with mine and they are very easily controlled, just be ready to get on the rudder once the tail is on the ground. I usually use a little power on final easing it off in the flare as the aircraft settles onto the main gear.
Other than that it's just a great overall aircraft that flies as good as it looks in the air. Other than the loose muffler issues that you may have read about in this thread, it's a solid aircraft with no problems and no surprises. It's one of my favorites.
Enjoy
Old 02-26-2014, 03:38 PM
  #329
Lifer
Lifer's Avatar
Thank you for the report! The full-scale uses 85 degrees of flap deflection. How much flap are you using on your model?
Old 02-26-2014, 05:40 PM
  #330
ronht
The manual called for 43 degrees however, I'm using 30 which is more than enough.
Old 02-27-2014, 02:39 AM
  #331
Lifer
Lifer's Avatar
Thank you, again.
Old 03-29-2014, 08:02 PM
  #332
tfarmer96
tfarmer96's Avatar
I got the maiden on my tf spit today. I now know yes the 6 oz of lead in the tail was fine. This is a great flying bird very fast and groves in the turns. No bad habits I could see flies like a spitfire..
Old 03-30-2014, 01:56 AM
  #333
Lifer
Lifer's Avatar
Any issues with the engine overheating?
Old 03-30-2014, 08:59 AM
  #334
tfarmer96
tfarmer96's Avatar
No issues with over heating that head sticks out a good ways. I will fly this the way it is and I may get another one to strip an glass to make a smaller version of my comp arf E199
ID:	1982726   Click image for larger version
Old 04-30-2014, 12:51 PM
  #335
ronht
Finally!!!!! Complete success over the lose muffler issue!
Take a hose clamp, completely unscrew it and then attach it to the motor standoff. Get a large enough hose clamp so when you tighten it over the standoff that the excess hose clamp band extends down over the end of the muffler. Then drill a hole for a self tapping screw to secure the hose clamp band into the end of the muffler. This stabilizes the muffler vibration and has completely solved my lose muffler issues.
Enjoy
Old 04-30-2014, 12:55 PM
  #336
Lifer
Lifer's Avatar
Is a picture possible?
Old 05-01-2014, 05:32 AM
  #337
SWORDSN
My Feedback: (13)
Enjoy
ronht. Let me guess you are using a J- tec muffler?
Old 05-01-2014, 05:34 AM
  #338
ronht
Yes.
I'll post a picture next time I have the cowl off.
Old 05-01-2014, 09:44 AM
  #339
SWORDSN
My Feedback: (13)
Yes.
Keeping it tight proved impossible on my P40 and P47.I used std muffler on my P47 and Slimline on the P40.Both are side muffler mount.
Old 05-04-2014, 04:47 AM
  #340
chandley43231
chandley43231's Avatar
Getting mine in 30 days
Old 05-28-2014, 04:49 PM
  #341
chandley43231
Where is everybody at getting mine next week and will be putting a 55 ra init with you Futaba servos
Old 07-06-2014, 04:23 AM
  #342
chandley43231
this https://www.youtube.com/watch?v=D0_n...GQ6zOhrnz0ZMSw almost done had to use only epoxy glue what an easy build going to put switches in the batery hatch
Old 07-06-2014, 04:41 AM
  #343
chandley43231
here is the decal sceam of my stitfire its of the 309 fg
Old 07-06-2014, 04:46 AM
  #344
chandley43231
i called the president of NASA national association of scale aeronautics an was told the color sceam would be ok since they changed there colors through out the war i painted the spinner red with rustoilem 2x came out great got my decals from callie graphics notice the battery hatch outline just left of the star thats where in going to put my switches need to jazz up the tail wheel an add a rear view mirror
Old 07-06-2014, 04:50 AM
  #345
chandley43231
here are some more usa spitfire pics guys
Name:	wing to spitfire.jpg
Old 07-08-2014, 06:46 AM
  #346
hjbledsoe
Has anyone put a Saito Fa-220 in this Spitfire. (I'm allergic toGas)
Old 09-24-2014, 06:02 AM
  #347
Sewerdude
My Feedback: (20)
Sewerdude's Avatar
This thread has been quite lately. Thinking about ordering one of these birds. How are you guys liking yours?
Old 09-24-2014, 06:06 AM
  #348
ronht
I love it and I would highly recommend it to anyone I have about 50 flights on mine
Old 09-24-2014, 06:23 AM
  #349
chandley43231
Do have to say the bird flys really great I had to send in my Robart retracts due to have it just checked out no major issues it will fly nose heavy if you have the gear down but when there up it flys where you want it to go if you do use the electrics from Robart they do just drop in I put some washers for spAcers under the retract rails to give elevation for the wheels you want the to be able to spin in the wheel pockets also run the LIpo battery a 2 cell to retract box I used a 1350 mah thunderpower battery with its own switch for it I have 3 switches in plane I didn't put any lead in this bird I just moved my life battery's to compensate have nano tech 2000 mah 6.6v batteries set up ran reduntent.
Old 09-24-2014, 06:26 AM
  #350
chandley43231
Watch out for the tail wheel control arm mine broke off at the rear connection when I was landing of course had no control and when into our feild fence all fixed now still flying great I just took a metal control arms off one of my winter builds and used it instead
