Reload this Page >
Top Flite Giant Scale Spitfire ARF
Old 06-24-2013, 10:11 AM
  #176
Free Bird
Default RE: Top Flite Giant Scale Spitfire ARF
Capt, I like what you did there. One big question though, how did get he cowl over the exhaust tubes?
FB
Old 06-24-2013, 11:21 AM
  #177
Capt G
My Feedback: (8)
Capt G's Avatar
The cowl has to be worked on over the loose muffler. There are two holes in the side of the cowl that line up with the muffler bolts and allow them to be tightened after the cowl is in place. You can work Loctite onto the bolts from the bottom. Just have to get the servo switches and ignition mounted now.
Old 06-24-2013, 11:29 AM
  #178
Free Bird
Now you tell me! LOL! I didn't even think to attach the muffler after installing the cowl. My exhaust tubes extend just a tad below the cowl. I'm concerned the exhaust heat will deform the dummy scoop. I'll find out either Wednesday or Thursday.
FB
Old 06-24-2013, 11:49 AM
  #179
Capt G
My Feedback: (8)
Capt G's Avatar
Took me awhile to work it out. How did your balance turn out?
Old 06-24-2013, 01:24 PM
  #180
Free Bird
Haven't done that yet, it'll be done tomorrow night.
FB
Old 06-24-2013, 02:24 PM
  #181
ronht
Capt G,
Where did you find the vent cover that fits so well? Looks like a great idea.
Ron
Old 06-24-2013, 02:43 PM
  #182
DUCATIKID
Having holes in the cowl to tighten the muffler is a good idea anyway, because it is very handy to be able to check the muffler bolts periodically for tightness.
Old 06-24-2013, 04:04 PM
  #183
Capt G
My Feedback: (8)
Capt G's Avatar
Here ya go. http://www.thunderboltrc.com/index.p...roducts_id=899
Old 06-25-2013, 03:55 PM
  #184
ronht
Thanks for the link to the vents.
Not sure I like the idea of having to remove the muffler everytime I need to take the cowl off.
Any thoughts given to cutting the muffler pipes down a bit and using silicone extension tubing to extend them after the cowl is installed? I'm using high temp silicone tubing from McMaster Carr to extend the exhaust on the pipes on my Extra 300 and it works great.
Ron
Old 06-25-2013, 04:23 PM
  #185
Capt G
My Feedback: (8)
Capt G's Avatar
Certainly another option. My friend who is using the DLE 55 RA has to use extensions on the stock muffler that comes with it.
Old 06-26-2013, 03:04 AM
  #186
Free Bird
A few pics....
Maiden is scheduled for tomorrow (weather permitting), still need to balance and setup the control throws.
FB
ID:	1895219   Click image for larger version
ID:	1895220   Click image for larger version
ID:	1895221   Click image for larger version
ID:	1895222   Click image for larger version
ID:	1895223   Click image for larger version
ID:	1895224   Click image for larger version
Old 06-26-2013, 03:20 AM
  #187
ronht
Looking great guys -  I'm just finishing up the wings today and am looking forward to reaching the point you're both at.
Let us know how your CG comes out - I'm looking forward to the maiden report.
Ron
Old 06-26-2013, 03:36 AM
  #188
Lifer
Lifer's Avatar
Just a suggestion, but you might want to re-route your ignition cable so it doesn't touch the exhaust stack. Best of luck on your test flight, and thank you for sharing your build!
Old 06-26-2013, 09:42 AM
  #189
Capt G
My Feedback: (8)
Capt G's Avatar
Thanks for the pics. Got my pilot from Lyle and like he says - he likes to provide more pilot than you need. I had to cut him off at the knees (Bader?). He was too tall to fit on the seat pedestal so I cut it off and reinforced the area with balsa. Fits ok now.
ID:	1895293   Click image for larger version
ID:	1895294   Click image for larger version
ID:	1895295   Click image for larger version
Old 06-26-2013, 09:48 AM
  #190
Free Bird
I didn't bother with the floor, can't really see anything anyways. The pilot really fills up the cockpit.
FB
Old 06-26-2013, 10:26 AM
  #191
DUCATIKID
I alsodid some 'plastic surgery' on my pilots knees to fit him in.
Old 06-26-2013, 06:01 PM
  #192
Free Bird
Lifer: good catch on the ignition lead, its been rerouted.
Capt: I balanced the Spit tonight, it was a little nose heavy, but not the same experience that you had. I'm looking at maybe an ounce. I'm going to fly it like this for the first few flights. Hopefully the weather will cooperate tomorrow, looks like we're going to get heavy showers for he next few days.
FB
Old 06-27-2013, 09:49 AM
  #193
SWORDSN
My Feedback: (13)
ORIGINAL: Free Bird
A few pics....
FB
I used the same mufflers on my p40 and P47. They would not stay tight no matter what I did. Finally used the stock muffler on the P47 and a Slimline pitts on the P40. Good luck,looking forward to your maiden.
Old 06-27-2013, 07:55 PM
  #194
ronht
Re: the muffler coming loose -
Clean the bolts in alcohol and let them dry, then use blue lock-tite and Permatex RTV instead of a gasket and you should no longer have any problems.
Ron
Old 06-27-2013, 10:52 PM
  #195
DUCATIKID
Yes i would second that, not using the gasket but rather heat resistent sealant instead is a large part of the answer to keeping the muffler tight
Old 06-28-2013, 04:57 AM
  #196
pacoflyer
My Feedback: (23)
FreeBird,
Do you have pic of your plug wire relocation.
I've got the same issue with a P-47/DLE55 combo I'm working on.
paul
Old 06-28-2013, 05:54 AM
  #197
Lifer
Lifer's Avatar
Not trying to hijack the thread......
ID:	1895779   Click image for larger version
Old 06-28-2013, 09:39 AM
  #198
Capt G
My Feedback: (8)
Capt G's Avatar
I routed the ign lead on the side opposite the muffler and across the top. It is zip tied to the standoff to keep it clear of contact. The "office" is ready for the pilot who is farmed out for painting.
ID:	1895832   Click image for larger version
Old 06-28-2013, 11:28 AM
  #199
SWORDSN
My Feedback: (13)
ORIGINAL: ronht
Ron
Tried all that and more,nothing worked for me except changing mufflers.
Old 06-28-2013, 02:46 PM
  #200
pacoflyer
My Feedback: (23)
I'll tell you what has worked for me...
As mentioned before clean everything up as best you can...alcohol,acetone whatever.
Then I wrap the muffler bolts with teflon tape, re install them not totally snugged down and then run the engine. After everything is warmed up, I shut down the engine and finnish tightening the muffler bolts.
I've never had one come loose doing it this way....hope it works for you.
paul
