Ed's Ziroli B-25 Build
#276
My Feedback: (21)
Just need to know where to look. https://ziroligiantscaleplans.com/b-...cowl-1135.html
Argggh! Thanks pal!
#281
Yep, was going to use G10 and 4-40 ball links, but after making one, found they are too big and wont fit in between the sheeting, so have to either use the plastic ones, or get a thinner sheet of G10 and 2-56 ball links. Its the bellcrank that I have to figure out, but have to get the sizing done first. I also need one of those center ball link 2-56 couplers, all I have are 4-40. The stab is not as thick as I thought.
#282
I ended up mounting wing servos in the fin itself, and the ele servos in the Horizontal stab as well. I know it'll take a bit more weight to get her balanced, but it is what it is.....
#283
That's what I am trying to avoid. I still have not chosen an engine for it yet. I would like to keep the tail as light as possible, the entire plane as well before making a decision. I want to go 4 stroke gas, and if I can get the weight to stay low, then a pair of FG-30's may work, or a pair of FA-180 with CDI may work.
#288
My Feedback: (13)
I will list them here.
I used a 10 oz slant front tank which gives me about 9 min run time in ground test.(12 oz would be better)
I mounted ignition on plywood plate zip tied to top two engine stand offs.DLE35RA
I hope Ed is ok with me using his thread
#289
Fili I have tried to respond to your B25 questions through RCU but I don't think you are receiving my answers.
#290
Just a few pics... I'm almost done with the riveting and panel lines. A few things to clean up and I can paint. I also need to finish my throttle cables, but I really want the bigger (21oz) tanks that are still backordered until early jan.
#292
I have G38s in my C47, I forgot how big the tanks are. I set my timer to ten minutes, typically I'm ready to come in by then. I've run over a few times, but never have run out of fuel. However, I really want to chase the fighters around this year with the B25. I'd like ten plus min if possible and not have to worry about running out and losing an engine. I think I'm going to have to go back and see what tanks I have in the C47..
#294
