Go Back  RCU Forums > RC Airplanes > Seaplanes
Reload this Page >
Shavrov SH-2
Seaplanes Aircraft that typically take off and land on water...radio control seaplane discussions are in here.
Shavrov SH-2
Old 01-12-2017, 03:05 PM
FlyerInOKC
FlyerInOKC's Avatar
Nice drawings I'm glad you posted them.
Old 01-12-2017, 04:44 PM
BigTeeEldorado
BigTeeEldorado's Avatar
Originally Posted by hipik634
so I went a little further today ... used a little carbon and ply to make the middle section, that solved the connection problem. Is it what you call improvization BigTee ?
You bet!!! That is exactly what it is. Fun isn't it!!
Old 01-12-2017, 09:50 PM
hipik634
hipik634's Avatar
Fun and challenge in one pack
Old 01-13-2017, 05:55 AM
FlyerInOKC
FlyerInOKC's Avatar
Yep! More fun then finding a live frog in your shorts!
Old 01-16-2017, 02:14 PM
hipik634
hipik634's Avatar
Small steps for now, as the weekends are reserved for family life
I've made sides and I've to start Appling the clear coat for the balsa to assure it will not capture any water in it. I have trouble with this on my seamaster. I am not exactly sure what to do with the vottom layer which would be then inaccessible from inside ...
Old 01-17-2017, 06:22 AM
  #31
FlyerInOKC
FlyerInOKC's Avatar
It's really starting to take shape!
Old 01-19-2017, 05:57 AM
  #32
hipik634
hipik634's Avatar
basic grinding done, now applying inside coating to block water from soaking in ...
Old 01-19-2017, 07:10 AM
  #33
BigTeeEldorado
Very Cool.....Nice Work
Old 01-23-2017, 06:22 AM
  #34
hipik634
hipik634's Avatar
meanwhile on our hill
https://www.youtube.com/watch?v=lHgkxbUr_mw&index=31&list=PLkg3v72zblUyEl_NEEUTpWR3EFlw4gVZu and more sanding ...
Old 01-23-2017, 08:58 AM
  #35
BigTeeEldorado
I read someplace in this forum that you're never done sanding you just decide when to stop
Old 01-24-2017, 08:18 AM
  #36
hipik634
hipik634's Avatar
Getting the engine done
Old 01-24-2017, 09:43 AM
  #37
FlyerInOKC
FlyerInOKC's Avatar
Looking really good!
Old 01-25-2017, 07:49 AM
  #38
hipik634
hipik634's Avatar
Old 01-25-2017, 09:24 AM
  #39
BigTeeEldorado
THATS pretty cool!
Old 01-25-2017, 02:03 PM
  #40
hipik634
hipik634's Avatar
more pictures after I get it by post
Old 02-05-2017, 06:22 AM
  #41
hipik634
hipik634's Avatar
the engine seems nice, i could finaly moved on as the servo leads were put in place. now last layer of lacquer and i would be ready to close the boat
ID:	2199724   Click image for larger version
ID:	2199725   Click image for larger version
ID:	2199726   Click image for larger version
ID:	2199727   Click image for larger version
Old 02-05-2017, 07:26 AM
  #42
Vettster
Vettster's Avatar
Very Nice work there Hipik
Old 02-05-2017, 12:06 PM
  #43
hipik634
hipik634's Avatar
uff I just closed the hull, some more layers of lacquer and i ll move on to cover it. Thats a little problematic - I plan to use transparent lacquer, then use L285 with glass to make the first layer of anti water surface. then I would use foil to wrap it all around. Any comments ?
ID:	2199776   Click image for larger version
Old 02-06-2017, 07:34 AM
  #44
FlyerInOKC
FlyerInOKC's Avatar
Upside down it looks like some kind of fish!
Old 02-06-2017, 12:00 PM
  #45
BigTeeEldorado
I like everything your doing, however the foil thing scares me a little. Especially over fiberglass, I used foil on a project a few years back and it is difficult to work with. It just takes time and patience and did I mention patience? The only tip I would offer is that I found success applying foil using a plastic credit card to smooth it as I was applying. And of course your fiberglass surface has to be super smooth because it shows every little flaw.
That is just me though, your efforts so far are commendable. It looks great.
Old 02-14-2017, 12:48 AM
  #46
hipik634
hipik634's Avatar
filling and sanding complete ..
Old 02-14-2017, 09:29 AM
  #47
FlyerInOKC
FlyerInOKC's Avatar
It looks like some strange speed boat without the wings. Very nice!
Old 02-14-2017, 02:06 PM
  #48
BigTeeEldorado
That is really one of a kind. Keep up the great work, I'm anxious to see the finished product.
Old 02-14-2017, 02:59 PM
  #49
hipik634
hipik634's Avatar
glassing .. and glassing ....
very confused about strength of epoxy L285 with 50 g/m2 glass cloth - when compared to 33 g/m2 it is really strong, used it for lower parts of the fuse
ID:	2201074   Click image for larger version
ID:	2201446   Click image for larger version
ID:	2201447   Click image for larger version
ID:	2201448   Click image for larger version
Old 02-20-2017, 12:41 PM
  #50
hipik634
hipik634's Avatar
i guess it isn't strong enough if it comes of your hand while sanding ...
