redcat volcano brushed want to upgrade
have a brushed volcano want upfrade to brushless and use 3s lpo 5000mah battery, can someone advise me on what motor and esc will work. also go fast and last a long time on a charge your help is apprieciated
Castle Creations 1/10 SV3 Sidewinder SC + 3800kV w/5mm shaft
Just have to remember what your pinion gears fit on what size shaft. Castle also has a ESC/3800Kv motor combo with 1/8" shaft.
Me, I'd grab HobbyWing EZRun WP-SC8 ESC, and pick a 550/3656 sized 3800Kv of your choice.
I personally can't give firsthand experience with that combo. My concern would be the 2 pole 540/3650 sized motor turning all four tires on the Volcano. Gear the motor right, and you'll be fine. Keep an eye on the motor temps 'til you find the sweet spot.
