JetCat Pump Power
JetCat Pump Power
I have a JetCat P20 which I'm running on a test stand, but it no longer reaches it's full power RPM of 245K - it gets to about 215K, although the 'commanded RPM' shown in the lower right of the GSU does indicate 245K, so it's not a radio calibration issue.
It looks to me like the pump power is reaching a limit/cap - but I can't see anywhere in the settings that this can be adjusted.
What are typical values for the pump power figure in the lower left of the GSU when running? Mine reaches 4.2 and doesn't go any higher - how is this limit set?
Thanks in advance.
Thanks in advance.
Run it at full power and hold the set button down, the rpm should increase to 245 and set. I can’t remember the max pump value on the P-20, you must be getting close. Your sure there is no restriction in the fuel system? What tank was it running before and now?
Thanks for the advice Dave - I'll try that tomorrow.
Pretty sure there's no restriction in the fuel system - the fuel piping is new, but it's the same 3mm OD/2mm ID as the original tubing supplied (and it has to be longer than usual for the P20, the required 1.1m loosely coiled on my test bed between the tank & engine). The filter is a hi-flow type.
Ref: the GSU - there doesn't seem to be a [Set] button on mine, could this be the [Change Value] button?
Thanks.
Yes, it's the older black rectangular GSU. I also have one of the mini-onboard GSU units, but its buttons are the same as the black GSU.
I'll try and source some Festo 3mmOD tube then - it's not some thing that you stock is it Dave? I notice that you have 4mmOD JetCat tubing?
