Official Muggy thread
#51
RE: Official Muggy thread
Coololdude, when did they start making the Crowd Pleazer for the Muggy? I can never find any bodies that would fit...some say the Revo bodies can fit on the Muggy...i just need something different, the body i have now is too pretty to drive with..lol...but the stock body is too plain..and orange...
#52
CA
hey bro... this body #3186...it fits the lst...you just have to go up one hole on your front pins....I like it.. now it just dosn't look like every other muggy on the track...and if your looking for a smaller body the desert rat for the lst fits too...[8D]
#55
ON, CANADA
ORIGINAL: buck hunter
2D where did you get the shims for the hex's on the axle
#56
Guys;
Ive read some many bad things bout the Muggy, clutch, bearings, etc. Im thinking of getting one but this whole thing makes it hard to decide. Have any of you experienced this problems? Does somebody know of Team Losi has addressed the problem and corrected it?
Thanks for you input
#57
CA
most people that run the muggy have changed the tires to the smaller truggy style and that takes care if smokeing the clutches every 4 tanks of fuel..and I've found it handles way better and it's not as clumsy off the jumps...and as far as what I've done with my clutch I've gone to an 8ight-T clutch setup...and I've put about 2 1/2 gal. on a set of clutch shoes
#58
ORIGINAL: hpicola
Guys;
Guys;
#63
ORIGINAL: muggy707
That is one slick looking paint job on that Muggy. I like those tires too...what kind are they?
#65
CA
I think it's time for a new look for the mug..with the new body and all. some bad lands with the bead locks would look crazy ...I think I'm going to bling mine out..."LOL"...as much as I can bling a muggy.....man I've seen some blinged out lst's...some look way cool...[8D]...I'm going next week to pick up my 8ight-t roller so it's time to bling the mug...
#67
I have been thinking about converting my LST to a truggy for some time now. I had already wondered how the clutch would hold up without a 2 speed........this affirms my thoughts on it.
So, if you want a monster truck for ultimate fun keep a LST or LST2 (NO Clutch Probs)! If you want to race trucks go with a truggy.
The muggy concept is great and would probably make great racing with a bigger engine and heavy duty clutch with the factory size tires......!!!!!!!!!!! Just a thought!
I will probably still make the conversion though because someone will make a steel or ceramic clutch for the monster power engines when enough people start buying muggies.
Lee
Lee
#68
TX
[link=http://lstvideos.com/04292007/MuggyPracticeSTS21T.wmv]Video: My Muggy with .21,Fironi clutch,proper gearing,MTR sized tires.[/link]
#69
I was wondering what the difference is between muggy shock length and LST shock length. They look short! If so, how much shorter are they and would original LST shocks fit without the bottom shock mount on the lower arms?
#73
CA
Cool 2d I've seen your vid's ..and that is a very technical track you race at.....have you seen the werk clutch or used one I almost picked one up the other day but wanted to ask some people about it.......oh and last time I talk to you ....I did get the one piece motor mount just waiting on my back plate for my engine....
#74
TX
Werks clutch is all I have used since November04 on my LST's....did not work on the Muggy. I use a Fioroni with a 12t vented clutchbell and a 48t spur.
#75
My Muggy has LST2 shocks on it...i got them because they have the aluminum shock shafts...they look good. I found out that the LST2 springs are a little longer than Muggy springs...so i ditched both and went with white springs.
