Juniaer K45TP Tucano from Brazil?
Hi
Does anyone have any experience or seen one of these planes?
https://www.juniaer.com.br/gallery/t...escription.pdf
https://www.juniaer.com.br/en/Turbo-Prop-45/
Looks like a nice size and weight airplane, full composite with some nice detail options. They make a similar plane for 20cc and 50cc as well.
I was able to contact them. They have a back log of orders and the shipping will be in March. There are TP, and 55CC versions. You can give 10% of the cost of the kit to reserve your spot. Since I have a Marchetti TP already, I ordered a 55CC version. will post when it comes.
Behzad
Behzad
Behzad
Behzad
Any choice of paint schemes or just delivered in white?
Which retracts do they use?
It comes painted. They have 4-5 schemes that you can choose from. has to be confirmed about 2 month before shipping. They have a set of scale retract for $ 1,200.00 or you can use Generic Robart ETC.
My Feedback: (26)
Tucano
I have one of their turboprop Tucano models
Still in the box, have not had time to get to it yet. Very nice kit, and they painted it and weathered it nicely after my selected scheme.
Good communications via WhatsApp and plane arrived on time, nicely packaged.
Extremely light weight. And the glass work looks good. Lots of scale details
I would not hesitate recommending it. Also got good feedback from a friend who already flies his.
GTaero2000 (01-19-2022)
The following 3 users liked this post by Neil Guildford:
Modified rear servo hatch cut and a former to strengthen servo area
Former secured with Hysol
Servo secured on its side and hatch mounting splints added.
Rudder servo in the rear to provide extra space inside the fuz up front.
Elevator servos fitted.
Juniaer Modelismo (08-17-2020)
Looking goog Neil. I am currently working on mine. Done with the wings and working on stabs. My friend Dr. Scoles cut some carbon control horned for us and I used BVM flap horns for internal Flap servo assembly. I thought the original control horns are too big but they work. One thing we have noticed here is that the tail flexes a lot during the flight so we are adding a horizontal former on the skinny part of the tail to help. Mine will be electric as I couldn't bear the sound of the 50cc motor in a slick plane like this. Probably will order a TP soon as well.
Behzad
Behzad
The following 2 users liked this post by Neil Guildford:
GTaero2000 (12-28-2021),
Will do as soon as I get there. To explain, made of 1/4 balsa about 7" long going horizontally on the skinny / flat part of the fuse in the middle (under the tab cut outs for front section of the stabs). This is how we used to fix the flex on the late 80's early 90's pattern planes And worked great.
Behzad
