Reload this Page >
~~SIG Brotherhood ~~
Old 01-19-2018, 11:34 AM
  #3026
acdii
You should have seen his last 168, done up all in red, looked really good.
Old 01-19-2018, 11:50 AM
  #3027
Captcrunch44
Originally Posted by FlyerInOKC
It's a pretty blue, what color are you going to trim it in?
not sure yet, still in the figuring out stage after I get it all covered then I will see what kind of design I can put on this one that blue is kind of boring.
And for you all that didn’t see the last one.
Old 01-19-2018, 12:12 PM
  #3028
acdii
hey, you got me in the background there messing with something in my trailer. And wearing my SIG hat!
Old 01-19-2018, 01:26 PM
  #3029
FlyerInOKC
FlyerInOKC's Avatar
Nice looking airplane and for a bonus you caught acdii in the act who knows what!
Old 01-19-2018, 04:02 PM
  #3030
acdii
Hey now! At least I still had my pants on.
I know what I was doing there. I was hooking up the extension cord to the inverter so that I could hit some covering with the heat gun.
Old 01-19-2018, 04:07 PM
  #3031
VincentJ
VincentJ's Avatar
Well with everybody showing their latest creations, I thought I would join in and show you my recently completed Sig Morrisey Bravo. It's done!
ID:	2251602   Click image for larger version
Old 01-19-2018, 04:12 PM
  #3032
acdii
Bravo!
Old 01-19-2018, 07:04 PM
  #3033
cmy6
Beautiful Moressey! I love the cowl. How did you do the river heads? What did you cover the airplane with? I really like it.
Old 01-20-2018, 03:10 AM
  #3034
skylark-flier
skylark-flier's Avatar
Excellent Bravo, Vincent! Well done!!!!
Old 01-20-2018, 03:15 AM
  #3035
Captcrunch44
I like the bravo had ome in the bones gave it to a fellow builder in hopes to see it fly.
Old 01-20-2018, 03:27 AM
  #3036
VincentJ
VincentJ's Avatar
Thanks Acdii and cmy6.
The wing was sheeted and then glassed before applying Klass Kote epoxy paint. The aft section of the fuselage was covered with Solartex then painted. The forward section of the fuse was also sheeted and glassed. The many thousands of rivet heads were hand punched using aluminum soda cans and lithoplate that a good friend supplied me with. Each rivet was attached to its surface using the tip of a soldering iron.
ID:	2251652   Click image for larger version
Old 01-20-2018, 03:29 AM
  #3037
VincentJ
VincentJ's Avatar
Thanks Dave!
Old 01-20-2018, 04:32 AM
  #3038
cmy6
An amazing job for sure. Do you need a special breathing apparatus using Klass Kote other than a standard cartridge mask?
Old 01-20-2018, 07:59 AM
  #3039
VincentJ
VincentJ's Avatar
No you don't. Klass Kote paint is not cheap, but it is the finest paint that I've ever shot from my gun.
Old 01-20-2018, 08:45 AM
  #3040
acdii
Some day I will get around to making my booth that vents outside so I can spray KK. Been using latex automotive paints for my warbirds, but have to shoot the clear outside, which means only in the summer, so it never gets done.
Old 01-21-2018, 12:03 AM
  #3041
knuckleball
knuckleball's Avatar
Is that a Sig Fazer in the upper-right background? One of my favorites.
Old 01-21-2018, 08:11 AM
  #3042
Captcrunch44
I don’t see it but these are two i just finished
Old 01-24-2018, 04:23 PM
  #3043
wetbird
wetbird's Avatar
Hello guys.
I'm building a Sig 1/4 scale Piper J3 Cub, I'm getting ready to start on the wing. I have a few questions on modernizing the wing for transporting. I know the wing comes apart for transporting as per the plans, but was wanting to make it a 3 piece where the wing panels plugs into the center suction. Has anyone here done that? I just kinda need to know where to start. I've been building RC planes since the early 70s, but have never build a 1/4 scale Cub, they've all been 1/5 scale float planes, so I'm not a newbie kit builder, just looking for a little advice to keep me out of making a mistake. I know I can figure it out on my own, but thought to check here and see what idea's I can get before I start. Not sure what size aluminum pipe to use, was thinking maybe 1/2 toward at the main spar and 3/8s aft. I also wanna get the dihedral right.
Any help would be greatly appreciated!
Gerry
Old 01-25-2018, 08:06 AM
  #3044
bobsrc
Just repeat what is on the right side and you will want to use separate servos for the ailerons.
Old 01-25-2018, 09:18 AM
  #3045
wetbird
wetbird's Avatar
Thank you Bobsrc, I'll have to check that out. I'll post what I end up doing with pictures.
Old 01-25-2018, 10:25 AM
  #3046
acdii
I would build it per plan up to where you want the section to end, then take that rib and make two out of plywood, use a tube and sleeve that fits that rib and a dowel pin at the rear to align them, and finish building the wing per plan so the length remains the same. Do the same for the other wing, then instead of following plan for the center where the wings would normally join, make a spar section that joins the two panels at least two ribs out on both and epoxy the center together. As for joining the outer panels, you will need to come up with that on your own since I don't have plans that show the wing. What I have done in the past is to use a 3/16 - 1/4" plywood plate that is epoxied on either the wing panel, or center section that slides into the wing and secure it with a T-nut and bolt or two.
On my B-25 I have a setup like this, the aluminum tube is glued into the outer panel, the plywood plate is under it on the outer panel, and the T-nuts are in a plate above the tube so the bolts go in from the bottom, through hardwood blocks under the tube in the CS, through the tube and into the T-nuts. Secures the wing tightly and only shows the small holes underneath where the bolts go in, the heads flush with the surface.
Old 01-25-2018, 04:44 PM
  #3047
acdii
https://www.youtube.com/watch?v=dDIv...ature=youtu.be
Old 01-25-2018, 04:46 PM
  #3048
acdii
Old 01-25-2018, 04:47 PM
  #3049
acdii
OK why did the first one just link and the second one load?
Old 01-26-2018, 06:43 AM
  #3050
FlyerInOKC
FlyerInOKC's Avatar
Weird I didn't have that problem.
