Juniaer K45TP Tucano from Brazil?
#151
GTaero2000 (12-28-2021)
#152
I’ll check my turbine readings next time I run it up, it does seem strange that my flight times are lower than others out there. I’m generally flying half stick with full for the vertical climbs, so nothing outrageous.
The Juniaer Tucano is a far superior finish to the JMB PC21 and a more manageable size. Having said that, the PC-21 was a very easy plane to fly and the landings were super slow.
The following 2 users liked this post by Aquilon:
GTaero2000 (12-28-2021),
PaulD (04-15-2023)
#155
Tucano is ready ! Maiden flight in a few days...
Touch-up paint and weathering will be added after the first flights.
Dry weight : 12,8 kg
Scale cockpit : Juniaer + jet pilot 12’’ by Warbird Pilots
Lights set : Juniaer
Engine : Wren44TP Kerostart by Turbine Solutions
UAT : Ultimate Airtrap 100ml by Digitech Aerosports
Propeller : SEP 20x14x3 @ 6000rpm
Spinner : Krumscheid aluminium 85mm diam. x 92mm length
Fuel : 1,6 l (Juniaer tank + CM JETS fitting)
Receiver : JETI CB200 + 2 RSat + RCSwitch
Gyro : Bavarian Demon Cortex Pro
Servos : 7xGraupner DES707 (control surfaces) + 1xHitec HS5643MG (steering) + 4x JX PDI-HV2107MG (gear doors)
Telemetry : Telemetry unit Xicoy (turbine) + MRPM Jeti (prop.)
Batteries : 2xNanotech LiFe 2S 2100 (radio) / 1xNanotech LiPo 2S 1800 65C (turbine+gear) / 1xTurnigy LiPo 3S 1000 (lights)
Retracts : Electron Retracts ER40 100° (nose) / ER40 90° (main)
Struts + wheels : Juniaer / Johnny Simoes
Brakes : Xicoy 36mm
Gear controller : CRU by Digitech Aerosports
Brakes : Xicoy 36mm
David J Ruskin (06-06-2021),
#156
Looks good, I like how you have done the aileron and elevator linkages.
Yesterday, I flew mine for the first time with the extra fuel tank and achieved 8 minute flights with enough fuel for a couple of go arounds.
#158
I had 4 flights with my Tucano last week. I still have to tweak the flightcontrol settings but it flys great. I have my timer on 6 minutes and after landing I have about 50% left in the fueltank with mixed throttle settings.
The following 2 users liked this post by Didier:
SaintExupery (11-15-2021)
#159
Tucano’s 3 firsts flights done today. What a great plane ! It flies perfectly, the Wren44TP fits like a glove.
Ailerons travels have been reduced compared to manufacturer recommendations, and a litle mix Flaps -> Elevator down is added. CoG at 130mm is a good way as basis. Slow down and landing are easy with little more flaps than recommended.
I will communicate my own settings as soon as definitely validated.
Stéphane
Stéphane
Neil Guildford (06-11-2021)
#161
Hello,
Some details about the K45TP engine mount modification to adapt WREN44TP.
I suppose photos are self-explanatory, but do not hesitate to contact me if you need more details.
I can supply the engine frame design in DXF file upon request.
Engine frame is made in sandwich Carbon 200g / 3mm Plywood / Carbon 200g / 3mm Plywood / Carbon 200g. Total thickness: 9mm
The gluing area of engine frame is reinforced with epoxy resin + microballoons filling + carbon cloth. Sorry, I forgot to take photo of reinforcement....
Upper engine hole is drilled in 5mm diameter, linked to the main fuselage frame with 5mm x 150mm length screw, with aluminium spacer 7x5 mm diameter.
Stéphane
Stéphane
#163
Hello,
This is the stock curved exhaust of the early version of Wren44TP (mine was bought in 2008).
Later modified on straight one on 2nd version of W44TP.
Stéphane
Stéphane
The following 3 users liked this post by Didier:
#166
Thanks.
I still fly the Tucano with the CG recommended. That means empty tank, UAT full. I have a little bit of down elevator with flaps up. Almost no down required during inverted.
#169
With the 14” pitch prop and K45tp, I found it hard to bleed off the air speed during landing with the suggested flaps settings due to the slick design and high idle rpm. So I programmed more flaps and a little bit of crow. Now the landing is more manageable. All is based on personal preference, length of runway and which engine you install.
#170
I just recently ordered the turboprop configured for the Xicoy. Plan is to install Electron retracts and Eurokitshop struts which are hydraulic.
As asked in another post, would folks with flying Tucanos be willing to share their control throw data (flaps, elevators, ailerons if different from manual). I am particularly interested in the flap-elevator mixing amount.
#171
Hi Didier.
I'm awaiting a Tucano for the Xicoy 45TP. Would have a few q's if you don't mind re. your landing gear set -up & brake conversion. I think of doing the same.
Have dropped you a PM on this matter. Hope you find the time to reply, would be much appreciated.
Speaking of the landing gear: has anyone weighted the Simoes struts with the original wheels?
#172
Hi Didier.
#173
Do look at Eurokitshop for struts. I have them on three airplanes and plan on using them on the Tucano as well this winter. Their struts are machined (not cast) to close tolerances and are hydraulically damped. Beautifully made and they eliminate any bouncing if the descent rate was a little more than ideal.
#175
Hello All,
Hereafter my settings validated after 20+ flights, perfect in my taste for scale manoeuvres:
TRAVELS:
Gyro CORTEX Pro individuals settings:
Overall gyro gain: 100% at low speed (gear down or full flaps), 60% in normal flight.
Best regards.
Stéphane
TRAVELS:
Ailerons : + 13 mm / - 9 mm - Expo 30%
Elevator : + 25 mm / -15 mm - Expo 35%
Rudder : +- 45 mm – Expo 35%
Flaps : Take-off : 17 mm / Landing : 55 mm - Elevator down mix : 12% (- 1,8 mm) - Butterfly : N/A
+ : Up / - : Down
CoG: around 130 mm from LE at wing root (as manufacturer's recommendation).Elevator : + 25 mm / -15 mm - Expo 35%
+ : Up / - : Down
Best regards.
Stéphane
GTaero2000 (02-16-2022),
PaulD (04-15-2023)
