Juniaer K45TP Tucano from Brazil?
#176
Which xicoy brake set up did you get I’ll be getting my tucano in a couple of weeks
#177
Hi ,
Brakes used are XICOY Electric Brakes FT 36mm. Power supply LiPo 2S : https://www.xicoy.com/catalog/produc...roducts_id=477
Didier and I manage the gears / doors / brakes with Digitech CRU, which is fully interfaced with JETI transmiter : https://www.digitech-aerosports.nl/p...uplex-2-4-jeti
Stéphane
Stéphane
GTaero2000 (02-16-2022)
#178
Thank you
Hi ,
Stéphane
Stéphane
#179
Hello All,
Some nice shots from my friend Pierre of the last flying day. Tucano now have 25 flight, and I'm playing very well with it!
Best regards.
Stéphane
Best regards.
Stéphane
#184
Hi All,
TUCANO review updated, taking account modifications applied on the airframe by Juniaer :
@éronews
KéroStart (french jets forum)
Stéphane
@éronews
Stéphane
#185
Hello, I am working on the fuselage with the aim of installing a Xicoy X45TP. The CG appears to correspond to the front edge of the wing joiner tube. I am trying to decide how to install the two factory fuel tanks. Based on the photos here, it appears that placing the tanks fore and aft of the joiner tube is the popular approach. My concern is that if the tanks are plumbed in series, which I would prefer to do for reliability, then a change in the CG in-flight is inevitable. Have folks found any noticeable changes in in-flight performance with the tanks straddling the wing tube?
shrek514 (07-28-2022)
#190
I made a few changes to the landing gear rails. I'll upload the photos soon. I got the Xicoy mounted yesterday and the exhaust cutouts in the cowling are quite a bit off, so that'll require some fiberglass work.
Can folks recommend a source for the the curved exhaust extensions for the Xicoy? Zimmermann Schelldamper has a set but they are quite expensive. Thought I'd see if there was an alternative.
#191
My Feedback: (53)
Can folks recommend a source for the the curved exhaust extensions for the Xicoy? Zimmermann Schelldamper has a set but they are quite expensive. Thought I's see if there was an alternative.
I also have a set from Kingtech Luxembourg…definitely nicer, as well a set from Zimmerman (needed custom extension)…..those are a piece of art
#193
I would appreciate it if someone could let me know what length exhaust bends they used? Distance measured from the exterior surface of the cowling (normal to the surface) to the inner surface of the extension would be best. I'm going to order from Zimmermann and you have to specify the length of the straight section.
I don't want to have them be too short and char the fuselage skin and wing paint. Thanks
#195
2FAS,
In my opinion, it’s more versatile to use modified K45 motor mount.
If in the future you need to swap engine from Wren to another brand, it will be easier to unscrew the motor mount and screw a new one.
Stéphane
Stéphane
#197
For those that want to build the 50CC version and use Electric motor, please be aware that the motors that are listed in manual fit but no other motor like hacker or the Espirit Elite would not fit. I learned this in the hard way by purchasing an expensive Elite motor and many different shaft extender etc. and none worked as the upper part of the cowl would not fit if installed.
behzad
behzad
#199
Hi behzad, I'm getting one of these to build as an electric, with an option to mount a xicoy X45TP down the road. What part of the motor is hitting the cowl? Is it the stand offs that have a bigger diameter than the motor itself, or is it the can on the motor itself that's got too big a diameter? What elite motor did you try before settling on the rotomax? Thanks!
I hope this helps.
Behzad
#200
