Reload this Page >
CARF Ultra Flash Evo build thread +
Old 02-13-2023, 04:05 AM
  #526
Dave Wilshere
Sound nose heavy if it’s that amount at the tip of the elevator.
Old 02-17-2023, 06:47 PM
  #527
Beavis
My Feedback: (19)
Beavis's Avatar
Could you folks please post the names and/or links for the various cool equipment trays for the UF that I see here? I've tried searching the thread but could not find that info. TIA
Old 02-17-2023, 07:56 PM
  #528
acw
Nothing too fancy. From back to front.
- cmjets 3L kevlar tank
- Electron retracts basic controller. You probably want the one with the Xicoy gyro and touch screen.
- BVM UAT
- Jersey fueling system
- Jetcat fuel pump and ECU
- Jeti Central box 220
- Bavarian demon Cortex pro gyro
Old 02-17-2023, 08:32 PM
  #529
Beavis
My Feedback: (19)
Beavis's Avatar
- BVM UAT
Thank you, this is also very helpful, but I meant the actual trays, for example the carbon fiber ones, the red one that Dave has on his latest UF, that other black board that I don't know what it is, etc. TIA
Old 02-17-2023, 11:40 PM
  #530
Dave Wilshere
My tray is the plywood black glass covered trays that come with the kit…painted red with a car rattle can.
Old 02-18-2023, 04:36 AM
  #531
Dansy
My Feedback: (53)
Dansy's Avatar
Nothing fancy…fuel pump and ecu under the tray….
Old 02-18-2023, 05:42 AM
  #532
Beavis
My Feedback: (19)
Beavis's Avatar
Thank you both
Old 02-27-2023, 04:02 AM
  #533
jetpower
After a recent house move
i have lost te servo cover plate's of my evo stab
would it be ok to replace them with g10 1mm fiberglas plate
or do i have to buy the original one?
regards
Peter
Old 02-27-2023, 04:34 AM
  #534
Dave Wilshere
G 10 will be fine. Just a few g heavier which is no bad thing
DW
Old 02-27-2023, 06:23 AM
  #535
scoeroo
My Feedback: (9)
scoeroo's Avatar
regards
Peter
1mm carbon fiber plate would look great -
Old 02-27-2023, 08:17 AM
  #536
jetpower
DW
thanks Dave
Old 03-05-2023, 09:28 AM
  #537
Dave Wilshere
Good to get the Evo out today, it’s so stable flying full flap circuits close to the ground, but a projectile opened up.
Probably one of the biggest speed differentials of any jet.
Old 03-05-2023, 12:50 PM
  #538
Andrewfordham
looks awesome Dave! I can’t wait for mine to come. I’m curious, I’ve seen mixed thoughts on the nose gear door. Some say it helps with slowing the plane down, some say it makes a cool noise when it’s off. Do you run one?
Old 03-05-2023, 01:04 PM
  #539
Dave Wilshere
Yes, I have the nose door. Yes it adds drag down and reduces drag up…win win
There is a pitch moment as the gear cycles if you are travelling too fast when putting the gear down.
Old 03-05-2023, 01:47 PM
  #540
Andrewfordham
That’s good to know! Thanks!
Old 03-05-2023, 03:03 PM
  #541
camss69
My Feedback: (46)
camss69's Avatar
Just got finished mounting the landing light in mine, waiting on the hysol to dry..
Old 03-18-2023, 11:20 AM
  #542
jetpower
Guy's need some help
i'm a big nob on installing thrust pipe's
I have alway's flown my jets without thrustpipe like kangaroo,boomerang xl, bobcat and aftel a long period of not building (new house etc) i recenly picket up building on my evo and i wanted to instal the thrustpipe
and wanted to align it with the fuse former see photo using a straight edge wood stick on one side
it toches the stick and ont the other side it is about 1.5 mm back from the former
I also noticed that on the widest part of the belmoth there is a bit of weaving/ not cut straight from the factory
should i leave it like it is see photo's
Regards peter
Old 03-18-2023, 01:32 PM
  #543
Dave Wilshere
The Bellmouths are cut from a complete duct, I usually sand them (with mask) on 120grit glass paper to get them flat.
The former might not be 100% square, so average it so you can screw it securely in place.
Old 03-19-2023, 12:25 PM
  #544
jetpower
Thanks dave for the answer
i looked at it again today and you are richt the forme is not 100% square .
Old 03-19-2023, 02:31 PM
  #545
camss69
My Feedback: (46)
camss69's Avatar
Ok so what’s the trick to getting the nut on the other side of the flap control horn? I’m inserting the bolt from the wingtip side but not really seeing how to access the other side?
Old 03-19-2023, 09:52 PM
  #546
Dave Wilshere
The fibreglass cover will flex out of the way. I held the nut with a pair of painted nose pliers with thin jaws
camss69 (03-20-2023)
Old 03-20-2023, 06:06 AM
  #547
JP-1
D.W.'s Ultra Flash in the air at the JMA Buckminster meeting over the weekend
Alistair Powers
The following 2 users liked this post by JP-1:
Andrewfordham (03-20-2023), camss69 (03-23-2023)
Old 03-20-2023, 10:01 AM
  #548
Dave Wilshere
I enjoyed this weekend with just the mighty Rebel Hot and my Evo UF, both are amazingly versatile models
D
Old 03-20-2023, 08:30 PM
  #549
camss69
My Feedback: (46)
camss69's Avatar
So I used my method of the hysol’d nut on the gear leg to mount the gear door on this plane. It works really well, the door is solid, really happy with the results again. Just need to finish routing the brake lines and the gear install will be complete.
Old 03-23-2023, 08:08 PM
  #550
camss69
My Feedback: (46)
camss69's Avatar
If anyone has the Art Scholl scheme and isn’t going to use their gear doors and wants to sell them… I might be interested… had an unfortunate Dremel slip. Fortunately it hit the gear door and not the wing…
