CARF Rebel MAX - Build Thread
#276
didn’t know there was a US distributor, I should be saving around 300 bucks over Carf price.
#278
Skunkwrks (11-07-2022)
#281
My Feedback: (53)
Anyway He has lots of parts….just not the complete set, even the factory build them as order …plus if you go to events like I do….Greg and Jenni go to practically to all large events, he always have parts on hand, which can be a life saver.
Canadian Man (11-09-2022)
#282
Guys, have anyone wired up a max complete with just the PB premium wire? Not the Maxi.
im using 20 AWG but it’s a PITA the covering is thick difficult to get in the plastic housings.
#283
Originally Posted by Kenrico;[url=tel:12756145
12756145[/url]]Guys, have anyone wired up a max complete with just the PB premium wire? Not the Maxi.
#285
PB Maxi goes in the plastic housings easily because of the thinner insulation coating. It’s only the Pos/Neg that is 0.5 the signal is sae as Premium 0.35.
I use Maxi on all models now, even my Rebel Hot.
Skunkwrks (12-26-2022)
#286
Maxi has been out of stock for a while. I’m using 22 and 20 awg from Hansen Hobbies the 22 works perfectly I’ve been using it for years now but the 20 is always a different story. I’ve never used the PB wire and wanted to do the Max with it but with no time frame on when it was getting back in stock I started with what I’ve always used. On my pro I used 22 all through but with the Max I wanted to go 20 or pb maxi for the longer length to the tail.
#288
My Feedback: (53)
I used Max only for servo’s and still use premium for everything else….
On the Max wires the Red/Bleu is bigger while the signal is the same size as the Premium
#289
Hmm I have a roll of the premium I originally got for the Max but was advised I should go bigger for the tail servos.
I have some maxi on order but no exact date when it’s coming, so I either wait and stop the build, continue fighting with this 20awg or use the premium I have on hand 😩
#290
My Feedback: (53)
#291
My Feedback: (99)
Get some from Aeropanda.....
They seem to have it now.
#293
Manny at Aeropanda has a good supply of everything we, the Jet community, use. I should have suggested Aeropanda first thing . Sorry, Kenrico and Manny.
Like Dave said, there isn't an issue with assembly into the pin, the insulation coat is softer and thinner than the Premium wire, and if anything, it's harder to much a good crimp on the signal wire without bending the pin fitting, too much making it harder to slide into the plastic housing.
Merry Christmas
Merry Christmas
#294
Hey y’all ,
did the Maiden plus 3 more flights on the Max Yesterday.
K235 has ridiculous amounts of power for the max( too much in my opinion. A 210 would probably be better suited for my small flying area), it cruises around at maybe 1/4 or a tad over. At 1/2 throttle its hauling!
flies awesome! A little more fine tuning and its gonna be perfect!
ill post the full video of the maiden!
The following 6 users liked this post by Kenrico:
Canadian Man (01-30-2023),
CobraJet (01-30-2023),
Dansy (01-30-2023),
Skunkwrks (01-30-2023),
smcharg (01-30-2023),
and 1 others liked this post.
AEROSHELDON (01-30-2023),
#296
Hey y’all ,
Glad to hear everything worked out smoothly and yes a half-throttle they fly quite fast but just sip the fuel . With all that extra power maybe you can load up a smoke tank since there's power to spare.
#297
Hey y’all ,
Congrats on the maiden flight! I also have the KT235 and I think it's perfect. I weighed in at 55.1lbs full of fuel, ready to fly during the LTMA check flight, and my field elevation is a little over 6000 feet. I'm not a speed freak but I like to be able to maintain speed on the uplines, add a 95+ deg day, and I may see a large degradation in performance. Still, for 95% of my flying the KT235 is the sweet spot for me...love the Max!
#299
Kenrico,
