Reload this Page >
Top Flite Giant Scale Spitfire ARF
Old 05-18-2017, 07:32 AM
  #476
kenair
My Feedback: (10)
kenair's Avatar
Originally Posted by 52238
You do realize that Top Flite has discontinued this airplane, right? Too bad because I still enjoy flying mine and would buy another if I could. Maybe they'll bring it back someday!
I'm enjoying the Spit pics.
I was down in Minneapolis last week, Hobby Warehouse had the giant TF Spit on the shelf, shop owner Tom says its $600.00. http://www.myhobbywarehouse.com/
cheers - ken
Old 06-19-2017, 12:30 AM
  #477
scubaozy
I just received the retracts and wanted to install them but it turned out that one of them is not working at all. It seems like worm drive is not moving and probably the motor is shutting down because it is blocked. Anybody have an idea about how to fix this? Should I risk loosing warranty and open it up? I must say that I am really disappointed with Robart electrics, I have another set in a corsair and it caused quite a few problems, too.
Old 07-09-2017, 07:08 AM
  #478
Shaun Evans
Shaun Evans's Avatar
Hi,
I've always thought Robart electrics are a bad solution in search of an imaginary problem. Plumb those air retracts correctly, and they work season after season.
Old 07-09-2017, 07:13 AM
  #479
JeffH
My Feedback: (43)
I agree 100% with Shaun. I have never had a pneumatic system fail feom anything other than my fault.
Old 07-09-2017, 08:21 AM
  #480
lrb75
My Feedback: (12)
There is/was a problem with the robart electrics. If you switch on power to the gear a few time without cycling the gear the motor keeps jogging the lead screw tighter and tighter each time until the motor cannot run the lead screw in the other direction without hitting the current limit. You can manually turn the screw just a little and it will free itself. I don't think you need to disassemble everything.
Old 07-10-2017, 03:46 AM
  #481
scubaozy
I am sure I could have fixed it but I didn't bother just sent them back. I have ordered the pneumatic version from tower. Shipping and customs charges will be added but I also think that electric are less reliable. @Shaun, did you actually use the HK Spit retracts? How did they work out?
Old 07-12-2017, 10:52 PM
  #482
Shaun Evans
Hi,
To be honest, I can't remember?
Old 08-30-2017, 06:41 PM
  #483
Katniss
Katniss's Avatar
I have acquired one of these Top Flite Spitfires.
The plane was not really even close to finished, so still a good amount left for me to do.
It did have a 60cc Gasser on the front, but one of the four prop bolts was broken down to 1/2" sticking out from the prop driver on the front of the motor.
I'm unable to remove that to try and replace it(must have had a ton of locktite put on it).. So, considering that only 3 bolts would hold the prop on, and probably the broken 4th one might cause an unbalanced vibration problem, I removed that motor from the firewall.
I have decided to convert this aircraft to electric.
Does anyone have pictures of how they did a battery hatch?
I'm leaning towards putting the batteries right behind the firewall.... Sitting straight up. This places them under the back end of the cowl.
Two 6s 5000 packs...if I can, allow enough space for maybe 6000 mah 6s for a bit more flight time later on.
The motor I'm planning on is a 50cc rimfire with a 22x10 prop. I have the white spinner that came with the plane(2 blade) as well as a black 3 blade.
So, how has anyone done battery placement on this plane for a conversion??
Old 08-30-2017, 06:51 PM
  #484
Katniss
Katniss's Avatar
By the way, the plane has pneumatic retracts installed in the wing halves already. They are the Vantex(hobbyking) gear that was sold for the Vantex 89" spitfire still for sale at Hobbyease.com. Last I checked, they had the retracts for sale at 40% off... About $95.
Oh.... And the fuselage has had the stock plastic covering removed and solartex applied in its place.
I'll have to paint the plane.
The wheels I have bought are the Robart Spitfire aluminum hub set.
Old 09-01-2017, 04:03 PM
  #485
Katniss
Katniss's Avatar
This is the installation I've done using the hobbyking tailwheel unit. To mount it, I used the metal bracket from the stock TF tail unit, removed it, then conjoined it two hardwood plates sandwiched and supported by two square dowel rods.
It's controlled by a separate servo than the rudder.
ID:	2230084   Click image for larger version
ID:	2230085   Click image for larger version
Old 11-18-2017, 05:29 PM
  #486
wantitbad
Default I want one !
I have several of the TF giant warbirds but I never got the Spitfire ,Please let me know if you know of one for sale thanks Mike
Old 11-18-2017, 06:21 PM
  #487
kenair
My Feedback: (10)
kenair's Avatar
back in May I was down in Minneapolis last week, Hobby Warehouse had the giant TF Spit on the shelf, shop owner Tom says its $600.00. My Hobby Warehouse
may still be there. call them.
cheers - ken
__________________
Old 11-18-2017, 06:29 PM
  #488
Katniss
Katniss's Avatar
Another option would be the Hangar 9 30cc spitfire at 81". Last I knew it was on sale for $539 at horizons website.
A little smaller then the top flite at 86.5".
I actually got one myself still in box that'll get built after I finish the TF spit
Old 11-18-2017, 06:54 PM
  #489
Mark Powell
If it's anything like the smaller Top Flite supposedly 'Mark 9' kit version it will be a scale nightmare. (The Hangar 9 big ARTF is fairly accurate.)
While I accept that in the USA there are probably not too many real Spitfires to look at there are zero excuses for the small kit one to be a 'wrong' as it is.
Old 11-24-2017, 04:28 PM
  #490
Katniss
Katniss's Avatar
Motor install and cooling fans. Batteries sit upright over the 4 fans. Air exit exhaust is through the vent on the chin scoop.
ID:	2246125   Click image for larger version
Old 01-15-2018, 08:35 AM
  #491
wantitbad
cheers - ken
__________________
Thanks Ken I did get in touch with Tom and he still had it .I am just waiting on Greyhound to deliver my Spitfire .Thanks again
Old 03-07-2018, 03:00 PM
  #492
Katniss
Katniss's Avatar
Progress on my TF Spitfire.
Almost everything is done. Motor is installed, retracts, cockpit interior, etc. Still need to CG it and seal the vinyl graphics. The sharkmouth teeth decal with the set from Callie Graphics doesn't have the correct angles and is far too shallow so probably not going to use it. The air intake grill vents on the forward bottom of the cowl also make it extremely difficult to make use of that decal regardless anyway.
Old 05-27-2018, 02:26 AM
  #493
scubaozy
Hi all, I lost one of the tires during take off which resulted in a belly landing. Am happy that I already installed the oil coolers under the wings, there is no damage at all. But now I am trying to source the set screws. Does anyone know the size? I have the parts list but it does not include the set screws. I’d be happy if someone could give me the specs. I live in Europe so it is pretty hard for me to estimate the imperial sizes..
Old 05-28-2018, 12:52 AM
  #494
Katniss
Katniss's Avatar
I have the Robart retracts, installed, but not the Robart oleo struts on my Spitfire. The struts I'm using are from a different spitfire that just happen to fit.
But, I have a few other planes with robart oleo that should have those grub screws. I can check when I get off work(11 hours from now).
Someone else might be able to tell you for sure though hopefully.
Old 06-04-2018, 11:52 PM
  #495
scubaozy
Thanks, I found it in TF manual, funny it is not in the parts list of the retract itself. I ordered it at a specialized store. Where are you going to set your cg? I have OS gt-55 with pitts muffler, I left the preinstalled weights as they are. It flew very nose heavy. Now I removed the weights and moved the batteries forward. It looks like it will balance at 148mm with 250-300 g weight in the front.
Old 06-05-2018, 12:07 AM
  #496
Katniss
Katniss's Avatar
I think I set it at 147mm. I also removed the lead nose weights. I made a hatch for my flight batteries, but also have receiver batteries forward of the firewall.
Old 06-05-2018, 09:30 AM
  #497
David Bathe
David Bathe's Avatar
Looks brilliant chaps... but that canopy? WT'?
Shurely they can do better than that.
Old 06-05-2018, 09:45 AM
  #498
Katniss
Katniss's Avatar
In the photo above, I hadn't taken the painter's tape off yet when snapping the picture.
Old 06-05-2018, 09:51 AM
  #499
David Bathe
No critisism on your work Katniss, more aimed at TF to supply such a moulded- soap type of canopy. The fit and finish of the real thing is shoddy to say the least.Shoukld be very easy to fake.
Old 06-15-2018, 04:30 AM
  #500
Katniss
Katniss's Avatar
Here she is out at the field. Unfortunately a maiden didn't occur as two servo horns in the wing were found to have cracked and split apart. Very odd thing to happen as they weren't like that the day before, unless they were hairline fractures. In any case, glad it did it before any flight attempt.
No I didn't over torque the screws and there's no binding happening on the linkage. Just some fluke thing.
One on an aileron and one on a flap, same side of wing. Maybe got caught on something in the car during the drive out to the field. No way to know.
There's no shark mouth decals simply because the air intake on the chin of the cowl is grated aluminum.
