Top RC Models MkIV full Composite Spitfire-a game changer
#552
Thanks w1nd6urfa thats great information, exactly what i was looking for! Thanks
Im looking at these retracts from hobbyking. And was wondering if the motor will fit inside the wing. These retract away from the motor. From the pictures it looks like there is plenty of space inside the wing. Could you see if a total length of 106mm will fit?
Here is the link:
https://hobbyking.com/en_us/turnigy-...-size-1pc.html
Thanks Martin
Here is the link:
Thanks Martin
I'm afraid they will not fit. As you can see in the photo there is not enough room between the retract mounts and the wing root, and anyway on this composite wing you don't have easy access as you would on a balsa-ply plane
I think these HK units are made for the Brian Taylor Spit which is designed to take outward-retracting gear?
#553
Hello everyone,
i was wondering if anyone has tried to mount an electric starter to his spit? I was thinking about getting one but im afraid it will not fit with the cowling. Thought about getting this one: Mile High RC - EME auto starter, DLE Electric Start,DLE Remote start, EME60, 60CC Gas Motor,DLE55, optic kill switch, great planes, omp, pilot-rc
Any ideas would be much appreciated.
Happy flying,
Richard
Happy flying,
Richard
#554
Richard you are correct the electric starter will not fit. I bought the EME 35cc with electric start for mine and it does not fit without hacking up the cowl. I'm going to have to remove the starter then I will be done with mine.
#556
Attachment 2215124 Almost purchased the same setup..ended up buying DLE 35RA.....
#557
Cut out the bottom section and enough room for the cylinder head to receive air. In addition, I also drilled holes in the cowl just rear of each exhaust pipe. Engine overheating is a problem with this model so in addition I also put a heat baffle between the muffler and the carburator. The holes behind each exhaust pipe can't been seen and it provides additional hot air escape route
#560
No flaps?
Those Spitfires do like as much as you can. Get 80 degrees and reduce elevator deflection. The model looks nervous.
More flaps make the model steady and just adjust throttle to decrease or increase sink rate
#564
Here some photos on how i got around fresh air supply without altering engine fearing for the FG-40 plus extra photos from the "runway"...
For extra cooling I replaced the 12 fake pipes with real 45* cooper elbows....
Just finished to melt and pour 1.8 Kg lead ballast. Photos to come later.
#565
Excellent Job..can't wait to see the cowl..Question...where did u get the 4 blade prop and spinner from..I really want to replace the two blade I have with a four blade..please give all the info on where to get it, Thanx
#566
What pilot did you use? thanks
#567
for the prop it is BIELA brand here is an exemple :https://www.lindinger.at/en/airplane...+Blatt&first=0
For the spinner it is cheap but you have to groove the prop space: https://www.topmodel.fr/en/product_l...t.php&rows=100
enjpoy
Marv
enjpoy
Marv
#568
I have not flu the AC just yet. I will start with 2 blade wood prop first...so i can break the lower coast equipment....
#569
Choice of engines
I put à SAITO FG40 i did had to add 1.8 Kg to CG it. A DLE 55R is about the same weight as the fg40 but 2x more powerful. It is not higher, it is 1 cm larger cylinder wise and 3 mm shorter from back to prop. I think it would fit. I did cut the firewall back to fit rubber mounts and the engine. The motivation to fit the FG40 is that I had the engine from an previous project.
#573
Thanks guys gor the input! I will se if a DA 50 fits or I will go with dle 35ra or da35.
I really hate adding weight to a plane. Will do everything possible to not add weight.
#575
Hey guys one more question
Which model from robart AIR retracts would fit on it?
I will not use the electric retracts
