Reload this Page >
Top RC Models MkIV full Composite Spitfire-a game changer
Old 07-21-2015, 02:44 PM
  #126
zrooster
Well then, here we go, my first build on RCU. I ordered the Hanger 9 Spitfire wheels as an interim option. The plans call for 100mm wheels...the Hanger 9s are 4.25" which works out to about 110mm. I miced the wheel wells at just over 120mm, so that should work. As stated, I had to open up the channel on the retract mounting point (photo) to accommodate the Century Jets retracts...not sure if this is required for the Top RC gear or not. I didn't have to take off too much material...most of it came off the wood at the forward mounting point to allow the metal flange on the retracts to clear the fiberglass skin.
You ou can see the gear dummied up with the control unit, reciever, and battery. The gear use a dedicated 7.4v LiPo for power. I ops checked them and everything works as advertised (so far), complete with a nice scale slow down... When the retracts arrived, the axel was 90deg off from where it should be for a spit. I called Century, and they explained that there are two set screws (allen head) on each trunion...you have to extend the gear to access them, then it's a simple matter to loosen the set screws, rotate the struts, and tighten them. I'll tweak them again when the wheels come to make sure everything lines up right, but pretty easy otherwise.
Previously, I stated that the manual is lacking...it's not actually that bad. There are some gaps, and chenglish, but it's OK. One flaw I found is with control horn mounting. It indicates that you place small type horns on the aelirons and flaps, but only includes a pair of them. My assumption is that the small ones go on the flaps (see picture). I haven't glued anything in, so please let me know if I'm smoking something. BTW, I'm using Loctite 9462 Hysol for all gluing except the canopy.
ID:	2110424   Click image for larger version
ID:	2110425   Click image for larger version
ID:	2110426   Click image for larger version
Old 07-24-2015, 04:48 PM
  #127
zrooster
Working slow but sure. As you can see below, I opted to use the shorter control horns for the flaps...seemed to be the logical choice. One nice technique include in the manual is to mask off the area around the horns before gluing them in. It worked very well and I intend to use it in the future.
Next up is attachment of the stabs... This is an area where the instructions are severely lacking. For example, you're supposed to drill a pilot hole through the stab into each of the carbon fibre rods and then install hardware. I like the mounting method, but where exactly does the hardware go? There are no measurements to say how far outboard to place the screws. It also only has you install hardware in the forward rod on each stab...this is the only thing that holds your stab on the plane... Personally, I'm not comfortable with just one screw per stab and intend to use at least two (one forward, one aft).
More to follow!
Old 07-26-2015, 03:34 AM
  #128
kmtranmd
My Feedback: (71)
What inside diameter of the Zero cowl, where engine head would sit?
Wondering if I can squeeze DLE 85 into this?
Old 07-26-2015, 08:13 PM
  #129
mups53
My Feedback: (41)
Working on an electric setup for the Spitfire.
We're installing the Himax 210Pro outrunner using the Castle Edge HV80 Lite ESC and a set of Power Unlimited 5S 5100 Mil 35C Lipo's
http://www.gator-rc.com/himax-hc6330pro
http://www.gator-rc.com/pu-35c-5s-5100-jst-xh
http://www.gator-rc.com/castle-edge-80hv-lite-new
Here's some pics of the build so far.
Mike Mueller
Thanks for looking Mike Mueller
Gator-RC.com
ID:	2111282   Click image for larger version
ID:	2111283   Click image for larger version
ID:	2111284   Click image for larger version
ID:	2111285   Click image for larger version
ID:	2111286   Click image for larger version
ID:	2111287   Click image for larger version
ID:	2111288   Click image for larger version
ID:	2111290   Click image for larger version
ID:	2111291   Click image for larger version
ID:	2111292   Click image for larger version
ID:	2111293   Click image for larger version
ID:	2111294   Click image for larger version
ID:	2111295   Click image for larger version
ID:	2111296   Click image for larger version
ID:	2111298   Click image for larger version
ID:	2111299   Click image for larger version
ID:	2111300   Click image for larger version
ID:	2111301   Click image for larger version
ID:	2111302   Click image for larger version
ID:	2111303   Click image for larger version
ID:	2111304   Click image for larger version
ID:	2111306   Click image for larger version
ID:	2111307   Click image for larger version
ID:	2111308   Click image for larger version
ID:	2111309   Click image for larger version
ID:	2111310   Click image for larger version
ID:	2111311   Click image for larger version
ID:	2111312   Click image for larger version
ID:	2111314   Click image for larger version
ID:	2111315   Click image for larger version
ID:	2111316   Click image for larger version
ID:	2111317   Click image for larger version
ID:	2111318   Click image for larger version
ID:	2111319   Click image for larger version
ID:	2111320   Click image for larger version
ID:	2111322   Click image for larger version
Old 07-29-2015, 06:54 PM
  #130
mups53
My Feedback: (41)
Building is progressing:
It'll be in the air early next week.
Thanks for looking. Mike Mueller
ID:	2111748   Click image for larger version
ID:	2111749   Click image for larger version
ID:	2111750   Click image for larger version
ID:	2111751   Click image for larger version
ID:	2111752   Click image for larger version
ID:	2111753   Click image for larger version
ID:	2111754   Click image for larger version
ID:	2111756   Click image for larger version
ID:	2111757   Click image for larger version
ID:	2111758   Click image for larger version
ID:	2111759   Click image for larger version
ID:	2111760   Click image for larger version
ID:	2111761   Click image for larger version
ID:	2111762   Click image for larger version
ID:	2111764   Click image for larger version
ID:	2111765   Click image for larger version
ID:	2111766   Click image for larger version
ID:	2111767   Click image for larger version
ID:	2111768   Click image for larger version
ID:	2111769   Click image for larger version
ID:	2111770   Click image for larger version
ID:	2111772   Click image for larger version
ID:	2111773   Click image for larger version
ID:	2111774   Click image for larger version
ID:	2111775   Click image for larger version
ID:	2111776   Click image for larger version
ID:	2111777   Click image for larger version
ID:	2111778   Click image for larger version
ID:	2111780   Click image for larger version
ID:	2111781   Click image for larger version
ID:	2111782   Click image for larger version
ID:	2111783   Click image for larger version
ID:	2111784   Click image for larger version
ID:	2111785   Click image for larger version
ID:	2111786   Click image for larger version
ID:	2111788   Click image for larger version
ID:	2111789   Click image for larger version
ID:	2111790   Click image for larger version
ID:	2111791   Click image for larger version
ID:	2111792   Click image for larger version
ID:	2111793   Click image for larger version
Old 08-01-2015, 04:44 AM
  #131
mups53
My Feedback: (41)
Here we go with more build pictures.
We had to devise a sliding tray system to get the 10S lipo pack more forward into the fuse. This part will be an accessory available on our site soon.
If all goes right the maiden flight will take place this weekend.
Enjoy!!!!
ID:	2112199   Click image for larger version
ID:	2112200   Click image for larger version
ID:	2112201   Click image for larger version
ID:	2112202   Click image for larger version
ID:	2112203   Click image for larger version
ID:	2112204   Click image for larger version
ID:	2112205   Click image for larger version
Old 08-03-2015, 10:23 PM
  #132
burtonboy05
Mike this is a great looking plane and I can't wait to see the electric version in action. I'll need to track down a vendor here in Australia.
A few things that I'd really like to see as some have mentioned in the thread already. A spinner that can accommodated a 4 blade prop for the scale wh0res out there like me and nice 4 blade biela would do the trick!
The zero and the P-51D look stunning, it would be nice if all these birds came in a clean skin version so you could easily paint your own plane and make graphics for it.
Final request - please give us a super scale P-38 lighting.......pretty please with a cherry on top!
I think that pretty much covers it.
All the best with these new plane(s) in to the US market, I hope you get the supply chain running smoothly and the sales should take care of themselves.
Regards Ben
Old 08-05-2015, 06:25 PM
  #133
zrooster
Mike, how'd you locate the mounting screw holes for the stab? I came up with a way, but would be interested to see if there are better ways/validate mine before I put any holes in the skin.
All, I'll post what I came up with shortly...sorry for the gaps, my job keeps me on the road ~17 days a month...
On a side note, got my H9 wheels in and am mounting the retracts tonight. You'll see I have my flap and Aeliron servos mounted... It's very straight forward. The L brackets are tapped on one side to mount the servos to the brackets. Use included self tapping screws to mount the L brackets to the servo trays. Only hiccup: one of the flap push rods wasn't threaded on one side...will see if I have something small enough to cut threads on the supplied rod, otherwise will use my own threaded rod. Used Hitec HS645 metal gear servos all the way around except for the throttle and choke.
Edit to add: Ran a two blade 19/10 across my test stand...it made the same power as the 19/8 (measured in pounds on my unscientific fish scale) at 16lb. I also ran a 4 blade 17/6 which made ~14 pounds (~1lb more than the 16/8 4 blade I tested). As a note, the MKIX had a 4 blade, not a 3 blade prop...still working to source a 4 blade spinner.
Pics:
ID:	2113009   Click image for larger version
Old 08-05-2015, 06:43 PM
  #134
burtonboy05
Hi Zrooster, if you do manage to find a nice 4 blade spinner please keep us in the loop.
Regards Ben
Old 08-05-2015, 07:26 PM
  #135
zrooster
You bet!
Old 08-06-2015, 03:57 AM
  #136
rc34074
Dave Brown will make you a 4 blade aluminum spinner - get in touch with them. They make very good spinners
Ed
Old 08-06-2015, 04:19 AM
  #137
zrooster
Thanks Ed! Will do.
Old 08-13-2015, 10:22 AM
  #138
mups53
My Feedback: (41)
I've done a lot of testing now on my Electric Spitfire. So far I really think it flys well.
The power is more than sufficient
I use the following equipment:
Motor: Himax 210Pro. It's a 20 pole outrunner light and efficient it's mounts very easily
ESC: Castle Creations Edge HV80. Perfect matchup for the Himax
Lipo's. Power Unlimited 6000 Mil 25C 5S in series to form a 10S pack.
Mounting the lipo's in the front of the fuse is a challenge unless you follow our method.
http://www.gator-rc.com/custom-slide...model-spitfire
We now sell as an accessory the Gator-RC Spitfire specific sliding lipo tray
I'm running the CG at 125mm behind the leading edge at the root.
Prop is a APC 2BB 19x12
8 Minute flight times are a breeze.
I realize that many say a Warbird has to be Gas. I did this to open the market to the many fliers who want an easy no muss no fuss alternative, Also many fliers fly at Electric only fields.
This is an option to have your cake and eat it to.
Gator-RC and F3AUnlimited.com is known for having all the Electric equipment for pattern planes. Power Unlimited Lipo's is our house brand.
We can help with those who feel uncomfortable with the challenge of learning larger E setups.
Thanks, Mike Mueller
ID:	2114278   Click image for larger version
ID:	2114279   Click image for larger version
ID:	2114280   Click image for larger version
ID:	2114281   Click image for larger version
ID:	2114282   Click image for larger version
ID:	2114283   Click image for larger version
ID:	2114284   Click image for larger version
ID:	2114286   Click image for larger version
ID:	2114287   Click image for larger version
ID:	2114288   Click image for larger version
ID:	2114289   Click image for larger version
Old 08-13-2015, 10:45 PM
  #139
mups53
My Feedback: (41)
Lee Estingoy's new 3BB Electric flew yesterday. Hacker motor I believe a Q80 11S for power. He's happy.The prop is a Biela. I think in the 17x10 range but not 100% sure.
Mike
Old 08-16-2015, 08:38 PM
  #140
mups53
My Feedback: (41)
The new Zero is now for sale as well as the P51D
Here is a video of the Zero:
https://www.youtube.com/watch?v=_qmKC1QZQoU
Old 08-20-2015, 06:51 AM
  #141
zrooster
Gents, sorry for the delay. Made a lot of progress over the last few days (been on the road a lot lately)...
Gear: This has been the most time consuming part of the process so far. This is, in large part, my fault. When I marked the screw holes to mount the gear, I did so with the gear in the up position with the wheels parallel to the wing skin. The gear retracted and extended smoothly with no issues. However when
I put the wings on the fuse, it became apparent that there was WAY too much toe out on the wheels. This was confirmed when I put the plane on the wheels...it didn't roll very well at all. OK, no problem, just rotate the gear so that the wheels are oriented straight along the axis of the aircraft, right? Wrong. Now the wheels hit the forward edges of the wheel wells. Part of the problem was my use of the hanger 9 wheels, which at 4.25" fit, but only just. No amount of adjustment or shimming would fix the problem...the wheels were either toed out too much or they hit the wheel wells. Bottom line, I had the choice of redrilling the holes on the wings or slot the holes on the landing gear mounting flanges. I opted for the latter, adding a flat and lock washer to help with security.
The next step was mounting the gear doors. I used 1/2" robart collars, but rather than using the recommended wire and brass tubing, I hydrasoled some light ply to the rings and attached the doors to the ply using the supplied screws. I intentionally cut the ply long, then once I had the doors centered, held them in place with masking tape, marked my mounts, and sanded them down to size. I had to play with the adjustment to get everything lined up and flush, but it wasn't too bad. Initially, the right gear was about 2mm from flush. After checking everything else, I found that the left main wheel sat about 2mm further in the well than the right. It turned out there was a small gap between the inboard part of the flange on the right main gear and the mounting point on the wing. I shimmed it with a couple washers and it was good to go.
The rest of the wing went together as advertised, except that one end of one of the flap push rods wasn't threaded. I replaced both flap push rods with some threaded 4-40 rod...I still used the supplied rod ends, but had to open the hole slightly. I did so by twisting a drill bit into the end of the rod end by hand.
Next I'll run through how I marked and drilled the horizontal stab for mounting.
Gerad
ID:	2115692   Click image for larger version
ID:	2115693   Click image for larger version
ID:	2115694   Click image for larger version
ID:	2115695   Click image for larger version
ID:	2115696   Click image for larger version
ID:	2115697   Click image for larger version
Old 08-20-2015, 06:59 AM
  #142
zrooster
Sorry, one correction on one of my earlier posts. The 4 blade prop I plan on using is a Biela 17/8 (I inadvertently put 17/6 on my previous post). I'll maiden the bird on the 2 blad xoar, and then fly her on the 4 blade thereafter. I'll post my stab write up shortly.
Old 08-20-2015, 10:41 AM
  #143
zrooster
Regards Ben
Dont know how I missed this, but a BIG plus 1 on the P-38...it needs to be big (bigger than the Zero and Mustang, like 100"+), and it needs to have the correct 4 segment fowler flaps! If you make it, I will buy it!
Old 08-21-2015, 11:25 AM
  #144
Lee Estingoy
Ha, didn't think it would end up being posted here.
Guys, this is a cool kit. Assembles in NO time. 99% perfect. Flies great.
Lee
Old 08-21-2015, 12:07 PM
  #145
mups53
My Feedback: (41)
Lee
Lee
Thanks and yes why not post it.
You need a tagline after your name. Your famous!!!!!
Mike Mueller
Old 08-24-2015, 03:08 PM
  #146
chris923
My Feedback: (53)
Zrooster,
Which CJM retracts did you order?
Old 08-24-2015, 05:28 PM
  #147
zrooster
They are the Top RC Spitfire retracts and I also got the tail gear. I haven't seen them listed on the sight yet, so you might have to call CJM and order over the phone. It is possible the main gear are adapted from something they already stock, but the tail gear is definitely specific to the Top RC Spit. Everything lines up and matches up right (I just installed it), the pull-pull set-up is exactly right...all I had to do was open the hole at the top that the main shaft goes through. The CJM tail gear is definitely sturdier/higher quality than the one that comes with the ARF (hence why I had to open up the hole a bit). The only thing I haven't figured out is how to mount the fiberglass close out panel that goes around it. I haven't seen the Top RC main gear in person, so I can't really compare, but the CJM version is pretty good quality. Sorry for the long answer to a short question!
Old 08-25-2015, 12:41 AM
  #148
chris923
My Feedback: (53)
The more detail the better!
Old 08-26-2015, 11:21 AM
  #149
chris923
My Feedback: (53)
Zrooster,
Did you also get CJM's Controller?
Old 08-26-2015, 06:24 PM
  #150
mups53
My Feedback: (41)
Videos of our new planes
P-51D
https://www.youtube.com/watch?v=EgT5-Vlk-OQ
ZeroFighter
https://www.youtube.com/watch?v=nT7HTI8m68U
Mike
